>I recently purchased an Ethan Allen table which is an espresso finish. My wife left a scented oil diffuser on the runner and some oil must have leaked through. I don't think it damaged the wood but the protective finish and the stain was removed and a bubbly residue remains. I can't get anyone to help on such a small project and Ethan Allen has been useless. At this point I'm going to try to do this myself. Any thoughts or suggestions would be very much appreciated.
>I'm not an expert on this, but when I was in the contract furniture business, we sold millions of dollars worth of desks and worksurfaces with finishes that looked exactly like this one. Odds are good that your finish consists of a sprayed-on dye/pigment stain followed by two or three sprayed coats of a catalyzed lacquer, possibly with a toner in it. What I don't understand is how a household product like perfume oil could have such a disastrous effect if the finish were catalyzed. So, I'm thinking it might just be straight lacquer, which you could test by rubbing a little lacquer thinner on it in an inconspicuous place. Actually, that damaged spot might be just the place to test the theory.
At any rate, the way our touch-up gurus used to handle repairs like this was to sand the affected area to bare wood, usually to about 220 grit using a block of MDF as a sanding block, touch up the stain to match the color, and then spray several light coats of Mohawk spray lacquer over the area. You will end up with a sheen that doesn't match, and probably some pebbly areas where the overspray is sitting on the adjacent finish. Build enough finish to fill the pores to the same depth as the originals, and then rub it out with very fine wet-dry paper (600 grit? Higher?) wrapped around a rubber block and moistened with water or wool lube or something (experimentation is key here). You really only want to get rid of the nibs and the overlaps.
At some point, there is a bit of artistry required to blend the repair in with the existing finish. If the sheen doesn't match exactly, you need to raise or lower it to match, using a glazing compound to raise it and fine steel wool to lower it. You also have to make sure the transitions to the surrounding finish are seamless. It is likely to be an education. The alternative would be to find a local refinisher and let them do it for you.
>Get a peice of glass and place it over the damaged area and try different colors on it. The glass will allow you to get the color close without haveing to apply it first. Then, once you are happy with the color. Apply some with a small brush and let it soak in. Now , you can giive it a light sanding and apply a coat of lacquer over it.
