Re: O T. PVC plastic components
Larry Clinton At Frankfort (Central)., Indiana
>Paul, PVC is widely available in almost every area in just about any size or shape you want. It is not one of the better (stronger, tougher etc.) plastics but it is one of the cheapest. Better ones are Delrin, Nylon, Lexan etc. - but they are not easily solvent welded. As to finding sources for the material you want, here is one source:http://www.usplastic.com/catalog/default.asp
I would also use the search engine "Goggle" and search for "Plastic supplier" or something similar - you may want to add your State and or city. You probably will find several near you - you may be able to call them and get what you need from their cutoff bin at low cost.
