Best laptop for use in RV
Malcolm Timbers
>I am going to be travelling a lot for the next while and I need a laptop that will run off 12 volt marine battery as I won't be able to charge up the laptop batteries very often. I only do word processing on the computer and need the use of a full function word processing programme and mouse because I do a lot of writing. I am working on a 500 page book right now. I will also need to use WiFi connections. However I don't need great speed or hard drive capacity for writing.
Re: Best laptop for use in RV
Re: Best laptop for use in RV *LINK*
Sawdust Everywhere!
>You're a good candidate for the recently launched MacBook Air!
solid state hard drive with built in WiFi.
5 hours battery life.
solid state memory will allow for less energy consumption hard drive does not have discs that spin continuouly to seek information.
If you don't like the Mac OS, I don;t see why you would it's so user friendly, you can always install windows on it on a seperate partition.
MacBook Air
Howard Norman
>I am a big fan of Thinkpads, I haven't bought a new one since IBM sold the business to the Chinese but I can say that the service is still great. I had a problem with my 2 1/2 year old T41 recentlly and they had it picked up by DSL and back to me in two working days.
Tom
>I think just about any laptop would run for a long time off of a 12v deep cycle....If you want to squeeze the longest run time out of it, look for one with a Core 2 Duo processor (labeled Centrino even better). That cpu is about the most energy efficient you can get (more so than a Pentium dual-core or an Athlon/Turion X2). While you're using it, turn off as many things as you can that you're not using (like wireless). You can also throttle back the cpu and dim the lcd. I currently have a Thinkpad with an 8-cell battery which I like, but I just sold a Dell Vostro with a 9-cell battery that got significantly longer battery ife.
Rob Lee
>HI Malcolm -
I travel with a Toshiba Tecra M4.. (a tad old now) - but has great battery life. I also carry a second battery to swap ...
For RV use - have a look at a small inverter - It should power your laptop just fine (ours has a generator, so we have 120V while travelling) - but the inverter works well too, when the genset is off.
Another thing to consider is using a USB memory stick as your "working" drive... then you don't end up spinning the hard drive as much...
Cheers -
Rob
Jesper, Denmark
Jesper, Denmark
>You can use the one you like best and run it off an inverter. The power consumption is minimal in relation to you other consumers.
I use this on the sailboat in the summer and have no problems with battery life of the house battery.
