Can't Find Seal Coat 100% Dewaxed
Howard
>After seeing the discussion below on soft shellac, I can't find this in the box stores, anyone selling it on-line??
Howard
Lowes in AZ had it last time I looked
Don in Northern Arizona
Re: Can't Find Seal Coat 100% Dewaxed
Steve Schoene
>Also check local paint stores or hardware stores with good paint departments. Stores like these often have better selections than the big box stores which increasingly focus on only fast moving SKUs. In most areas that are likely to be several real paint stores for each Home Depot in the area. Too often a forgotten resource.
Re: True Value
Jay St. Peter - Southern, MD
Re: True Value
Howard Norman
>I think that it depends on the local store. Here the local True Value store is a very upscale hardware store that carries a lot of items that I have never seen in any other True Value store. The same can be said for Ace hardware stores, they vary a lot between individual stores.
Larry Clinton At Frankfort (Central)., Indiana
>Don't know where your located - here in Indiana I know Menards, Lowes and some Wallmart's carries Seal Coat (all Seal Coat is 100% dewaxed). As far as online, Klingspor's, Woodcraft and Rockler all carry it in quarts (and I think in gallons). Look at the WoodCentral Marketplace - All the vendors there are sponsors of WC.
GaryMc
>Local Woodcraft has it, about a buck more per can than the Big Box (but then it is likely to be fresher, too!). I wish it came in less than quart quantities...cutting it to 1 lb or so doubles the volume, of course.
Speaking of True Value, that is one of the few places around here that carries nearly "pure" denatured alcohol (Sunnyside brand, 96% ethanol). The KleenStrip in HD, for example, seems to be around 60%. I don't know what the other 40% might do for shellac, but it probably isn't good.
Re: Can't Find Seal Coat 100% Dewaxed *LINK*
pecker
>Rockler has it and shipping is free until March 23.
http://www.rockler.com/product.cfm?page=10310
Re: The Other 40%
>Is largely methonol, far more toxic which is an issue when applying shellac indoors. I personally look for high ethanol product.
OUCH!
Jason Roehl in Lafayette, IN
>I haven't priced it lately, but we were paying around $18/gallon for it--we use it as the "seal coat" (ha ha) on wood floors.
Jason
Keep looking,...
Chad Pearson
>I have found it here in MN for the low 20's. Rockler is a little high on this one.
Al Stokka - Cambridge, Iowa
>I found mine at:
Aubuchon Hardware
http://www.hardwarestore.com/
Nice folks to deal with.
Al
Una pregunta, por favor
Andy Halterman: Rain and wind
>You had any problems using that stuff on wide (6"+) planks? I've had it crack and start to flake off on long edges during the winter heating months. Had to stop using it because of that. Bummer cuz the dry time rocks-da-house!
BTW, Home Depot sells it under the Parks Universal Sealer label in a purple and white gallon can. Same stuff.
Andy Halterman
Dodging the flying tree parts in Hendersonville, NC�
Ellis: Andy's talkin' dirty!...I think.
Re: Una pregunta, por favor
>We used to spray it on 2x6 T&G white pine floors in log homes (we don't do biz with that particular GC anymore...), but we've never had any callbacks for it. We were only putting down 1 coat generally before 2-3 coats of Bona Mega.
If you're wondering about the spraying, it was with an airless, and it was because the WP floors had too big of gaps in between boards to pour and snowplow the finish on...plus, it was FAST.
Jason
Just wondering
Dan Donaldson
>Are you sure that the Parks is the exact same stuff? I can believe that it is dewaxed shellac, but my understanding is that sealcoat is a bit different in the formulation to give it a much longer shelf life.Michael Dresdner was involved in its development and from what he said, they have a patent on the formulation and it took them quite some time to develop.
Re: Just wondering
>Dan,
Parks is a division of Zinnser. HD has their stuff whereas Lowes has the regular sealcoat. I found this link via google.
http://www.newparks.com/profinisher-pg.html
I remembered reading the cans when I had some of both here and the instructions were basically verbatim. That and the division of Zinsser stuff pretty much confirmed that.
See, I growed up in MI so that means I can cypher things real quick like. :-)
Andy Halterman
Off to the blue borg in Hendersonville, NC�
>I had problems with it on heart pine. We get some major humidity swings here so perhaps that was the issue. One house in particular the folks built a million plus casa and then cheaped out by not putting a humidifier on the furnace. Things shrank so bad that it actually broke the screws holding the second layer of subfloor (5/8 4ply BC). That was the worst one but we had some minor issues on 5" oak and with a couple other heart pine floors as well. Tricky stuff this wide plank.
Andy Halterman
Currently on hiatus from an 8-11" wide heart pine installation in Hendersonville, NC�
>We get some pretty wide humidity swings here, too. Hot and humid in the summer, cold and dry (sometimes cold and humid...that's the worst) in the winter.
Some of the log homes we did were a ways out of town, so we would take a microwave, coffee-maker and sleeping bags to work on them. In the dry winter, you could hear the logs cracking and popping at night.
I bet that 8"-11" stuff goes down FAST!! One of my biggest installs (don't do many) was some 1.5" to match what was there...felt like it took FOREVER.
Jason
Fast? I wish..........
>We glue and nail anything that big. Big rooms average about 600 feet a day provided the milling is consistent. Good thing is I get 50% more plus materials for doing that kind of install. Still a good money maker.
BTW, the humidity swings I was referring to take place over the course of a day. 50%-60% daily swings aren't uncommon during fall, winter and spring.
Andy Halterman
Bequeathed a few shekels to the Blue Borg in Hendersonville, NC�
Thanks Andy
Dan Donaldson
>Learn something new every day. Funny, I live in MI and it ain't done a thing for my cypherin' ;-)
Thanks Everyone-I found it at a local paint suppli
Howard
No comprendo
>Don't tell me we need Spanish speaking moderators around here. :-)
Ent�o...
>...vou falar portugu�s.
Jason
Re: Ent�o...
Dan Donaldson
>E español aquì tambien.
