Further explanation - option
Dan Barber
>Some good explanation there Mark, but there is some newer technology that is emerging in some locations; basically it is ISP hosted wireless. What it amounts to is a high power 802.11 based system with about 1/2 mile coverage radius.
What you described as wireless is a self hosted system; you need some type of broadband service in your home and then you add a wireless router to provide the "wire free" connection to your PC's in and about your house. With the new services, the broadband wireless is provided from high power "hot spots" and you do not have a separate broadband connection to your home - the wireless provider is the only broadband you need. This does not use cellular phone technology, just WiFi.
So this makes the options all a bit more confusing. As it presently stands in our local area most folks can choose from the following methods to get internet connectivity:
Dial up
DSL - using the phone line
Cable
Cellular - air card or tethered phone (I use both)
Satellite (I also use this)
Wireless - from a local ISP
This wireless does not require you to have a ISP for your house other than the wireless itself. The nice feature of this is that you don't need a land based phone line, cable, cellular or a satellite to have high speed connectivity.
The draw back is that you need to live within 1/2 mile or so of a high power wireless transceiver. There are about 60 in a 20 square mile area nearby. I don't have that luxury pout here in the hills and hollows of Middle TN, so I use satellite and cellular connections here at home. I live in a bit of a dead spot (cellular) so I have installed a cellular repeater and antenna at the house. I still have random outages, so I retained the satellite (Hughesnet - but that is a whole different story). My main objective was to get rid of the $55 per month land line that quit working every time it rained - mission accomplished on that account - no more expensive land phone line that was used for nothing but home security system monitoring. The monitoring is now IP based via the satellite.
Sorry if I added more confusion - check your local area to see if you can get the Wireless ISP - it is only $24.95 a month here.
Cheers,
Dan
