Soft shellac finish
GolfSteve in Calgary
>I've only finished two projects with shellac. One was a side table that I French polished. The other was a turned candy dish.
If anything is left sitting on the table for any length of time (eg. a week), marks will be left in the finish deep enough that they need to be sanded out. I'm not talking about leaving your anvil sitting on the tabletop - in one case a quilted fabric coaster left thread and weave marks in the finish. This table was finished with orange shellac. The table is about two years old now, and the finish is still soft.
The candy dish was sprayed with shellac then polished up with abrasives. The finish had cured for at least 1.5 months . Last week we threw about 15 business cards into the candy dish. The corners of the cards dug through the finish (see picture below). The finish on the bottom of the dish is also marred just from sitting there. This candy dish was finished with dyed blonde shellac - so I cannot blame both the candy dish and table problems on a bad batch of shellac since they were made from different flakes. (Both shellacs were prepared from dry flakes, used Lee Valley's denatured alcohol as the solvent, and were applied within two months of the flakes being dissolved. The shellac seemed to dry hard).
Any ideas about this? I'm sure shellac is not supposed to be this soft.
The only thing I can think of is that in both cases I did some wet sanding on the dry shellac using low odour paint thinner as lubricant - might this have interefered with the finish hardening?
