WC Weekend Accomplishments.....
Dennis E. Peacock
>3 Mar 2008
Good Morning to all of you.
The LOML and I finally got our greatroom all finished up. All the old wallpaper borders taken down, cleaned the walls and baseboards, took down the ceiling fan, and got busy.
All the walls took 2 coats of paint, we put 2 coats of ceiling paint on the ceiling (boy what a difference that made), and painted all the patched holes in the walls.
The woodworking that went with this project was me making a false beam out of some Cherry I had in the shop. Planed and machined all the cherry for this project and spent the next 2 days working on ladders, upside down (seemingly) putting up wood, nailing, and fussing because the ceiling was no where close to flat...but, don't get me started on poor house construction).
Anyway...to make a long story short....the new beam is up, finished with satin poly (did I mention how much I dislike the slow cure of poly?), the room is all painted, the ceiling fan is in its new location..properly in the center of the room at the crown of the ceiling, and all that is left to do is patch the hole where the ceiling fan once was. The LOML is happy and so am I. I just hated finding muscles that I hadn't used in a long while during the whole project!!!
So what did YOU do this weekend?
Best of weeks to you all.
Dennis
Re: WC Weekend Accomplishments.....
Jason Roehl in Lafayette, IN
Played Appliance Repairman...
>...among other things. Saturday, I went out to a friend's house to cut up some very large logs for him. He had started weeks ago using my Husqy saw with the 32" bar on it. Not long after starting, he hit an embedded chunk of concrete (couldn't see it from the outside of the log). Well, I spent several hours sharpening that chain, only to find out that when I ground off half or better of the teeth, they lost their temper and were worthless--they wouldn't stay sharp more than a couple cuts. (He's going to buy me a new chain at his insistance--I would have let it go if this one could have been returned to usable). So, that was a bust.
Then, last night, LOMLWMBO went to bake some crescent rolls to go with supper, only the oven wouldn't come on. "Igniter," says I. After some digging through the manuals, I find that the igniter for the broiler is the same part as the one for the oven (NO WAY--FORESIGHT BY THE DESIGNERS!). No problem, we don't use the broiler much, I'll just switch them. Too bad one of the screws holding the oven igniter in place was installed by someone with a pneumatic wrench and rigor mortis in their trigger finger. Good thing I had four-letter words and various other tools with which I was able to rip it out (munching that threaded hole in the process, of course). I also bent the bracket to the point where the igniter wasn't close enough to the burner to light the gas, so I dealt with that this morning.
In addition, I put in a new (old one that I took out last summer when I replaced both) cable-thingy for the door counterbalance springs in the dishwasher. One broke last summer, so I replaced both (newer design), but then one of the new ones broke (newer--not better--design) a few weeks ago.
I'm starting to wonder if everyone around me has the anti-Midas touch...
Jason
>Saturday I made it to the Rockler sale - bought two more Triton wood racks and a 4' clamp. I also had to accompany the LOML to the department stores hunting for Clinique deals though. That's okay though, made it by Sur la Table store and picked up a nice covered non-stick wok - and the hunt for the deals didn't last too long.
Sunday - pruned a lot of bushes after church. The burn pile is getting pretty large.
No woodworking though :(.
Nathan
>Since I'm a beginner in woodworking, I decided to deal with my lack of skill by "throwing money at it" and bought a horizontal slot mortiser. Over the weekend I finally got around to cutting mortises with it. My wife makes fused glass jewelry and she needs frames to display them. So I made a frame using loose tenon construction. I cheated and made the mortises a little wider than the tenon. The frame turned out OK.
Now that I have the slot mortiser, my little non-tilt table saw is looking pretty pitiful. I'm making a wall rack for my clamps and decided the best way to hang it would be french cleats. Making the 45-degree rip involved using a jig to hold the board 45 degrees to the blade, ripping the board and then cleaning it up on the jointer.
Anyway, the clamp rack has turned out to be pretty complicated - I think tomorrow I'm going back to making frames. It's a good way to try out different types of joinery. Still, I know my desperation at having clamps all over the shop floor will eventually force me to finish it.
I helped my nephew move into the new BR
Keith Newton
>See the new Shop Shots that David Yoho posted below. Maybe when we get the windows washed, I will turn my camera around to the other side of the room, and up to the trusses.
I have just started a new piece of furniture for the TV which will sit just to the right of that fireplace.
John Veerkamp
>Seems like I drove over half the state of Texas. Drove from Houston to Whitsett(south of San Antonio) and bought 300 lbs of beautiful mesquite from Harold Jambers. From there to Fredericksburg. Next day to Auetin. Next day home to Mo. After three weeks in warm weather it was a shock to feel the temps drop to 30. But Am now back home with lots of wonderful wood to turn.
Jay St. Peter - SoMD
>I built some storage. First, a cabinet to hold some Plano storage boxes for my hardware. I moved my screws and jig hardware from some cheap plastic drawer units on my miter saw station and was able to use the wall space behind it to hang a piece of plywood and start hanging some tools on it.
Jay
Justin Fields
>Among other things, I built a two-angle miter sled. One direction gives the angle for 12-segment rings and the other gives 20-segment rings. Then of course I had to try it out and cut 8 rings worth of pieces. Next, I start gluing up what will be my first attempt at a segmented turning.
Justin
Bartee
>Just a suggestion, but STOP and paint that brown plywood white. It reflects light so much better...
I have committed to that in my shop and it is amazing how much brighter and nicer the shop feels.
Worked on My Morris Chair
Mike Fitterling
>Been working on this Stickely designed Morris chair for a long, long time; keep getting distracted by hurricanes and work and such. I finally made up the four posts. So each side has the quarter sawn face showing, I made them up as shown. When finished, the edges will be chamfered so the glue line is at the intersection of the chamfer and the faces.
Jay St. Peter - Southern, MD
>I've been thinking about that as more and more of my bright white walls are getting covered up.
That piece is actually really nice Cherry veneer. The plywood itself not so nice, but the veneer looks nice. I had problems with the other half of this piece delaminating and the face veneers are so thin that if I hit it with 150 on my ROS it immediately turns purple (the color of the glue holding the veneer on). Works well for what it's doing now. Someday I'll get a can of white and spray lots of my shop fixtures though.
