Mineral Oil
Mineral Oil
Mineral Oil
Debra Sullivan
>Mineral oil was used on an antique finished wood box. It darkend it and now it has a glossy finish. Can anything done to reverse it? Also can mineral oil cause cracks or warping on a finished piece? Thanks!
Re: Mineral Oil
Re: Mineral Oil
>Mineral oil is a non-drying oil. You won't be able to eliminate the darkening effect without planing or sanding off the oil-soaked wood. Depending on the species—particularly whether it is open pore or closed pore—this might involve removal of an unpredictable amount of wood. Unless I miss my guess, the glossy effect is just the surface sheen of the oil, as you would have on a cutting board soaked in mineral oil.
Ellis Walentine, Host
Re: Mineral Oil
&emdash?
Dave Bair, Eaton Rapids, MI
Re: Mineral Oil
Typo
>I sometimes use HTML expressions to insert symbols into posts sometimes. The expression for an em dash is mdash (preceded by a & and followed by a semi-colon). I mistakenly typed "emdash" instead. Duh.
Thanks for the catch. It's fixed now.
Re: Mineral Oil
Re: Typo
>Would that we ALL could dodat.
Re: Mineral Oil
Re: Typo
Rod Peterson -- Ormond Beach
Edit or use HTML entities? Former would be nice—I use entities in almost every post I make (including several in this one). You can, too. There's probably even a file in your OS (if you're using a windoze) that lists all of them. It's not all that easy to find, however.
On my desktop I've placed a shortcut which has this path: “C:\Program Files\Microsoft Visual Studio\Common\IDE\IDE98\MSE\1033” If you follow that path (using windoze explorer) and click on the HTMLREF.CHM file in the 1033 subdirectory, a window will open up which gives you three choices. Click on the following as the choices appear:
Dynamic HTML,
DHTML References,
HTML References,
HTML Character Sets.
There will then be four more choices, any one of which may have your desired character in it—it depends on what you're looking to do, and all will become clear (AWBC, as I always say) when you get there.
You can make a shortcut for your desktop by right clicking the above HTMLREF.CHM file and selecting “Create Shortcut”. Some filetypes will create a shortcut icon right in that subdirectory, others will ask you if you want to place it on the desktop. If the former, just click and drag the new shortcut to the desktop.
There are also websites easily found by doing a search on html entities which will get you started while you're agonizing over the preceding.
One caveat about using entities: if you use preview a lot (and you should—I always preview any post I make with HTML entities in it—too easy to make a typo—ask Ellis) be sure to back out of any previews to your original working Reply window. Otherwise, some of the entities may fail to render properly due to having been rendered already—the system no longer parses them as entities because they have been rendered by the preview mechanism to the character the entity represents. Sometimes it doesn't matter; sometimes it does.
Rod
Re: Mineral Oil
Ummmm. . Thanks, Rod
>I was refering to editing posts (to catch the spelling, missing words, etc.
I'm not going near HTML. I have touble enough with english
Re: Mineral Oil
Jason Roehl in Lafayette, IN
No joy.
>My IDE98 folder only has the file "ASP.TLB" in it. Perhaps I need to check for updates to Visual Studio...
Jason
Re: Mineral Oil
joy. *LINK*
>Ask Mrs. Google nicely or try the link below.
try here
Re: Mineral Oil
Same here, Jason. Only "ASP.TLB" listed.
Al Stokka - Cambridge, Iowa
Re: Mineral Oil
One thing to watch:
Dan Donaldson
>It is not a problem with the entities, but if you ever use any html tags in your posts, please make sure to close them. It messes things up if you don't.
