plywood definitions
plywood definitions
plywood definitions
Johanna
>What do K.V.C. and CCII mean in plywood description? The examples I am looking at say: "Rift White Oak K.V.C" and "Rift White Oak CCII". I presume V.C. indicates veneer core, but what's the K? I have no clue at all about the CCII.
Re: plywood definitions
Thomas S Stockton
>Johanna,
I would guess the ccll means classic core which is a veneer core with an mdf outer layer the face veneer is applied to. It would be best to ask your supplier what they mean because It all applies to proprietary terms and there isn't an industry standard like for grading of the faces. For more information try the Hardwood plywood & veneer association web page they have some useful info.
Tom
Lee Grindinger
I'm curious too
Lee Grindinger
>I did a quick search for the terms and came up empty. I'll venture a guess, however. I'll guess the terms refer to European standards, perhaps UK or elsewhere. The "K" refers formaldehyde emissions, moisture rating or structural strength, or another property of plywood.
Th CCII refers to glue or exterior/interior ratings, perhaps gassing properties, perhaps fire ratings.
These are guesses but I doubt the answers actually matter to a cabinet maker not looking for particular properties required by unusual parameters.
Johanna, perhaps you'd email the company and ask, I'd like to know.
Lee
"K" is a grade of veneer core
Henry Higginbotham
>The core quality, not the face. It has to do with the smoothness of the core veneers, size of voids, etc. In the Columbia Forest Products publication, "A Product and Grading Guide," they show "K" grade as below "K+" and above "L" and "M" grades. I could scan the specs page and email it to you if you want, or you might find it somewhere on the 'net.
Lee Grindinger
Thanks Henry, I'll take that scan
Lee Grindinger
>I'd appreciate it,
grin@furniturecarver.com
Lee
Re: Thanks Henry, I'll take that scan
Henry Higginbotham
>It'll be tonight, Lee, but I'll send it your way.
AHA!
Johanna
>Your post led me to Columbia Forest Products web page. In their "Ask the Experts" area, I found that J (Jay) core and K (Kay) core indicate the allowable openings in the core layer immediately under the face veneer. J core has fewer and smaller openings than K core.
Also it appears that CCII probably indicates Combination Core type II. I found this definition: "There are two types of Combination Core construction. The first type consists of a center veneer core and a crossband veneer on both sides of the center with a layer of MDF, particleboard, or hardboard under the face and back veneer. The second type consists of an oriented strand board or wafer board center with a veneer crossband on both sides, under the face and back veneer. Combination Core can be used when the project calls for consistent flatness and good screw-hold ability, without the weight of a MDF or particleboard core."
Thanks for steering me in the right direction. I will ask the local Lumber Products vendor if the above is correct -- and whether the CCII has a veneer core or an osb core.
