Re: ADVICE WANTED; Marble for counter tops
>I've done several kitchen tables with marble tile. I used MDF for the substrate, and glued the tile down with vinyl tile adhesive. You will need several longer straight edges (at least 3') to get your tiles set level to each other in both directions.
Joints were set at 1/16th (corner shims make life easy) and, instead of grout that will stain and/or crack and have to be renewed, I used 30-minute epoxy tinted to match the stone as filler. Tables have done well.
For the epoxy, let the adhesive (or thin-set) dry for 2-3 days after you carefully remove any squeeze in the joints. Then start by paste-waxing the top surface of the tile. Fill the joints with epoxy using a thin blade to work out any air. Then, when the filler gets to the "leather hard" stage, slice off the excess epoxy with a razor blade, followed by a wipe with alcohol. Stay away from acetone and similar solvents as they will attack and ruin the factory polish on the stone. Wait several days for a good solid cure, wipe down with alcohol to remove the wax, and apply stone sealer/polish.
What edge treatment are you going to use? I use a chamfered wood strip that matches the rest of the piece. If, however, you're going with a marble edge, you're going to have to do some polishing.
mm
