200+ woodworking book reviews
Steel City Mortiser - - First day report
Pete in Holland, MI
>Today I purchased a Steel City bench-top hollow mortiser.
During assembly, fit, finish & instructions were pretty good. The only issue I had with the instructions is that there was a Phillips screw and large OD washer that didn't show up in the parts diagram, but was burried in the instructions as to where it went. All & all, pretty happy thus far.
I have had a JET drill press mortiser & bits for several years and have been pretty happy with its performance. I had very little issue with drilling square holes with this set-up. Just thought is was a little rough on the drill press rack & pinion, thus the desire to look into a bench-top unit.
Upon installing the Steel City bits, per the instructions, after every hole or two, I get a jam-up of chips just behind the cutting edge of the drill/chisel that will stall the motor, and in the case of both my 1/2 & 3/8 chisels, are now blue. The chips just don't seem to pump out of the drill/chisel very well. Have tried drilling pine & white oak with the same results.
For curiosity sake, I installed one of the JET drill/chisels into the Steel City. and they performed well.
Has anyone else had a similar situation with Steel City cutters ? Are they simply not any good ? Surface finish too rough or tool geometry not right? Will be hunting down the salesman early next week on this issue.
Pete
Re: Steel City Mortiser - - First day report
Neal in San Jose
>It is not just the Steel City tooling. I had problems with a couple of name brand sets before I finally got to where I can tune them to work reliably. The problem it sounds like you are having is that the augers and/or the inside of the chisels are not smooth enough to let the chips eject freely. What I do is to polish both the insides of the chisels and the flutes of the augers, especially down near the "business end". It is pretty easy, really, and will make a big difference.
I take about a 6" piece of dowel slightly smaller than the inside diameter of the chisel and cut a lengthwise kerf half way up the dowel with my bandsaw. Take a strip of sandpaper and secure one end in the kerf, wind it around the dowel, chuck this polishing rod in my drill press and polish up the inside of the chisel. I start with fairly coarse sandpaper and progress up thru 600.
I purchased some rubberized polishing disks for my Dremel tool on eBay, and use them to polish up the outside of the auger. Just do a search on the 'bay for "Cratex" or "rubberized abrasive" - I just did and it appears the same 50 piece set I got is up for sale - that's about 5 lifetimes worth for 10 bucks plus shipping!
I don't know why the manufacturers don't do a better job of preparing these things for use, but I even got a "professional set" that retailed for about $100 per chisel that needed a serious touch up. I horse-traded for 'em and didn't pay anywhere near that price, and as far as I can tell the two differences are that the steel seems to hold an edge better and the sizes are spot on. Niether a biggie. YMMV
Rick Snyder
>Thank you for the Steel City Mortiser information. I bought one several weeks ago. I have not taken it out of the box yet. It sounds like I will also have these issues to deal with. Some days you just can't win.
Thanks again for posting the info.
Rick Snyder
Seem to recall
>First, let me just say that I don't have a mortiser so this is not based on experience.
I do remember several years ago reading threads similar to this about the Delta benchtop mortiser. IIRC there were two sets of chisels/bits available. Those that came with the machine (made in Asia), and another set available seprately (at 3 times the price) that were made in Germany. Many people complained about the quality of the original ones and had only good things to say about the German ones.
Perhaps this will help.
Happy Woodworking!
>Ditto on what Neal says. I have several cheap sets because I don't use them often and couldn't justify any extra expense. I polished both the inside and outside of the bits to an almost mirror shine. They work perfectly. I would still like to get a dedicated mortiser some day. I would probably use it more.
Larry Clinton At Frankfort (Central)., Indiana
>I haven't had any experience with the Steel City tooling. However, I can recommend the "Guild Craft" bits that come with the Fisch mortiser. These came highly polished, lapped and were very sharp. I did nothing to them before use and have had no problems. They cut within .002 of size. I do spray the bits before and during use with Bostich Dry coat (router bit/saw blade dry lubricant). The lubricant seems to reduce the friction between the chisel and bit - may also help with the chip clearing. I do have to pick out shavings occasionally - but they are near the top of the chisel opening. I have used the 1/4" bit to cut several hundred mortises in white oak and locust, did have to sharpen them this year. I intended to replace them with "better" chisels - but really haven't seen the need to do so yet.
Steel City Mortiser chisels
Denis Ch�nard, Orl�ans, Ont.
>I have the same machine, and I wasn't impressed by the chisels and bits either. I didn't get jams, but the mortises were rough and it seemed like I had to use more pressure than expected. What I found was that the chisels weren't very sharp (and roughly finished on the inside), and the bits were very dull. For the chisels I bought the cone sharpener that LV sells only to find out that the geometry is different from the SC chisels. Then I found this:
http://busybeetools.ca/cgi-bin/picture10?&NETID=1246450302081783512&NTITEM=B2469
Installed in a hand brace this tool does a good job of cleaning the chisels' interior and getting the edges sharp. One could then use a slip stone (or sandpaper wrapped on a dowel) to further refine the edges, but I haven't done it so far.
As for the drill bits, I used a small diamond file on the leading edge of the augers (they really needed it). I also sprayed some dry lubricant on the parts. The end result is a much smoother action, the mortises are cleaner and the bit/chisels require substantially less pressure to work.
One should see the SC chisel and bit set as a kit, that you have to tune before use. But once there they work well.
DC
Re: Steel City Mortiser chisels
>I bought a similar set from Woodcraft but mine also includes a diamond hone or plate about the size of a playing card. The Countersink/sharpener was so effective I just turned it with my hands. I may have chucked it in a hand held drill for some of mine. The diamond hone is for the outer face of the bits. I polished mine further on some 1500 grit sandpaper. I slide the bits up and down in the direction of travel so that whatever grooves were left would be vertical and offer less resistance on the way in and out.
I sharpened the bits with a small diamond file. Had not thought of polishing the bits themselves or the interior of the bits.
My bites are thirty seven years old from Delta. Never used them until recently.
