Internal Clamping of panels
Ron Hildreth
>I'm building a large base cabinet for a client, and for several reasons
(basement too small, and clamps too small!) found I was better clamping from the inside to draw the plywood mitered corners together, rather than doing it from the outside, as what is considered the usual way. I cut two cleats,dadoed slots in them for my band clamps to slide under, spot hot glued and clamped them about a 1/4" either side of the miter joint. Next, I cut some scrap pieces to length as bracing, to insure that the corner remained a perfect 45 degrees after the band clamps were snugged up. Biscuits were used to help align the miter joint.
I'm hoping this opens up a good discussion on alternative clamping methods.
How would YOU have done this, if not allowed to clamp externally???
Ron in Iowa
Re: Internal Clamping of panels
Ron Hildreth
>Another photo showing miter;
BTW- Still had to cut the dado to accept the plywood bottom.
Ron in Iowa
