A55 Smoothing Plane
Lazy Susan
Lazy Susan
Lazy Susan
Lazy Al
>I'm building lazy susans in kitchen corner wall cabs, the turntable has 20" dia. and is mounted on 12" dia. ball bearings. I'm generally following the methods in the Fine Homebuilding V133 article bit am having problems getting the edging glued to the turntable. The FHB article is for base cabs with a 32" dia. turntable and it specs 7/32" thick edging. I've thinned it down to 1/8" and am still not getting a good glue joint with the smaller dia. turntable. I'm using web strap and clamps to hold it together during glue up (see pic). Any ideas on other methods for building a turntable w/ an edge to hold stuff on? I thought about making the turntables octagonal, but that's a lot of work for a lazy susan. Thanks
Re: Lazy Susan
Lee Grindinger
These are tough
Lee Grindinger
>It's tough to get a band of solid wood wrapped around a disc without gaps, it's really tough. One of the problems is that to create a lip strong enough to resist cans and bottles and cookware you need at least an eighth of an inch thickness. This means you have a piece of wood that's stronger than your band clamp. There's only so much pressure you can put on that band and it's probably not going to be enough to bend that wood to your susan's will.
The edge of the susan must be DEAD ON square to the face. Any waviness from square will translate into gaps and this is probably your problem and it's the tiniest of waviness that will cause issues here. I'll assume you're cutting this susan with a router and, frankly, a router will not cut it close enough to avoid some gapping. The circumference of the top of the susan edge and the bottom of this edge are not identical and your wood strip simply cannot conform to this outage.
The solution is to accept the gapping and use a gap filling glue like plastic resin. Putting a small rabbet in the band will conceal the gap. A 1/16" rabbet will conceal the gap nicely but this can effect the way the wood bends, your band clamp will have to be as wide as the wood strip.
Also, I see you have two bar clamps on the band in your picture. I used a scarf joint on bands like these and after the band clamp was in place I used only one bar clamp and that was over just the scarf joint. Multiple bar clamps will only worsen the problem since you really need to lessen the length of the wood band to make the gaps go away and bar clamps will not do this.
The good news is that it will be strong enough even with the tiny gaps and that once the susan is in the cabinet and the cabinet is installed no one will notice the small gaps.
Lee
Re: Lazy Susan
Re: These are tough
Lazy Al
>Thanks, you nailed it Lee. I did use a router and I had to use the bar clamps because I cut a slice, ~10" long off the circle as it fills the cabinet better that way, and the web clamp wouldn't get the ends tight. I plan on puting a piece of straight edging on that will overlap the ends of the round one.
Re: Lazy Susan
Another possibility
>I have made little corner spice shelves with small radii like this -- maybe smaller -- and I got strips of aluminum for the edging. With a bending roll, you can make the curve match your shelf exactly. Then, all you need to do is screw it on with flat-head sheet metal screws.
If you don't have a set of bending rolls (who does?), check out a local sheet metal shop or a roofing supplier. They might be able to sell you the aluminum, too.
The trouble with a wood lip on a shelf this size is that you need to make it so skinny. Even if you do get a good glueline, that edge is going to be very vulnerable to all kinds of dings etc. from bottles, pots, pans, whatever. The solution is to laminate the edging to an acceptable thickness one half at a time, wrapping the laminates over a form of the same profile as your shelf curvature. Trim the halves perfectly (or scarf them if you want to be really tricky) and glue them onto your shelves. Voila!
Re: Lazy Susan
Use iron-on edging -- $0.20/ft
Re: Lazy Susan
We did a punch, but it was a long time ago
>When I was in the cabinet business with my friend, we did a lot of lazy susans. This was back in the day before we started buying the ready made ones. We cut the disks out of plywood and used tempered 1/8 hardboard for the strip around the edge. In one that was particularly pesky we laminated two layers around the outside and another layer inside the rim to hide the joint.
As I recall, (Its been almost forty years), we wrapped the strip around it and glued it on, but over lapped the ends and left the glue back about two inches from the outer one on the over lap. Used a band clamp and the occasional Bar clamp to hold it on. Yellow glue. Once the glue set, removed the clamps and sawed through the strips at the over lap with a thin kerf saw. ON the ones we laminated the strip on, we just repeated the process. After we got the joint cut, we glued the last little bit. The piece that went on the inside was easy. Just cut it to be a snug fit inside the circle and glued it in.
The Tempered hardboard was very flexible and turned chocolate brown under the influence of the lacquer. You could veneer the outer face if that makes you happy. You can also use a strip of plastic laminate for this.
Re: Lazy Susan
Re: Lazy Susan
>We build a number of different sizes of corner cabinets and buy most of the lazy susan shelves but have not been able to find a 23" diameter for a 27 x 27 corner unit. So we build our own. We cut out the correct diameter in a piece of 3/4" plywood to fit the shelf with the banding around it, a form I guess you would call it. The form is split in half and then just clamped with bar clamps. As has been mentioned you can't apply enough pressure with the band clamp. Witht he form and regular bar clamps you can apply a lot of pressure. The aluminum edging that Ellis recommends would also be a good solution.
Re: Lazy Susan
Try this exceptional product... *LINK*
David Barnett - SW Florida
>...and build up a rim as thick as you need with softened veneer strips. This stuff works amazingly well. I've made round container forms as tight as 3 3/4" diameter this way and upscale coat hangers with even tighter bends. Watch the video on this link.
Also, check out tutorials/videos on luthier sites. Guitar builders bend solid wood over a short pipe with a torch flame or BBQ grill electric lighter inside for a heat source. Nothing quite like the smell of steamy wood on a chilly morning.
Super-Soft 2 Veneer Softener/Conditioner
Re: Lazy Susan
Did mine with bent laminations.
Mac in Indy
>A few years ago I made a couple of lazy susans for my mom and wife to set on the middle of their respective DR tables. Mahogony plywood centers with four or five 1/16 plus strips of solid mahogony laminated around the plywood. I found doing them 1 at a time worked best. I tried several at once but too slippery!
Mac
