Jointer Problem Revisited
Tomm
>Thank you for all who wrote about seeing light and not seeing light before gluing boards together. Someone asked if the jointer was properly tuned. I have never been able to tune the jointer and always thought the fence was warped. I bought two expensive straight edges and used the longest one and found out the table was off .002 in the middle of both beds. That should not be enough to cause gaps in the boards. After three years of messing with everything that should make the jointer work properly and lots of calls to the tech line for help, I finally discovered that the beds do not line up side to side. They are off .018 in the six inch span. I think it is time for a new jointer.
