>My son is trying to refinish a deck. It is made of PT wood. The people that lived there before him used a turkey fryer on it and got grease on it about 4' square. Sanding it doesn't seem to remove the grease. Is there something to take the grease off the deck or what can he coat the deck with to hide the grease.
>I don't have much hope for the outcome, but strong bases, like lye (Drano), react with fats to make what amounts to soap, which can be rinsed away. (Saponification? if I recall my chemistry.) That grease probably goes very deep into the soft pine, but if the lye solution can penetrate just a little way, the surface may appear lighter when it dries. Of course, the grease might soak back up to the surface.
All this is speculation until you try it. I would suggest neutralizing the lye with some vinegar after it does its work.
If that fails, another option would be to darken the rest of the deck with linseed oil or something.
Either way, try sample areas before you decide to proceed.
>I would try something like TSP (tri-sodium phosphate) before I tried the lye (Drano) route. In either case (Drano (lye) or TSP), make a paste of the material, rub it in and then let it sit for a while.
Wear gloves and don't get any on your clothes or skin!
After it has sat, rinse with a dilute acid solution (vinegar and water). It will probably take several applications.
You are saponifying the fats (making them soap). If you want to try dissolving the fats, that might also work - but you would have all the nasty solvents to dispose of.
>I agree with Ellis on this. Actually, I think there is a vanishingly small chance of cleaning it and having it match the balance of the deck, even if you clean he whole deck.
You can get deck cleaning compounds at the Borgs. You could contact the companies that make them for advice. Or you could call the Butterball Turkey Hot-line and blame this on them. Maybe they have an idea how to clean up the mess they have made.
I think my choice would be to oil the rest of the deck, either with the same thing they fried the turkey in or linseed oil and let it go.
>I would visit a pressure-cleaning forum on line, see what those guys say, since they see this every day. They are also a great source for the best deck finishes, sealers, etc.
