drilling porcelain tile
Ed O'Neill
>Does anyone know of good drill bits that dont die after one or two holes drilling porcelain tile ? Ed
Re: drilling porcelain tile
North of the Border
>I have had no problems with using bits that are intended for drilling concrete materials. Carbride bits will hold a long longer too.
Neal in San Jose
>Go to a "real" tile outlet and get the ones the pros use. Not "Tile-R-Us" or the like, I mean the tile stores that serve the pros. They will be somewhat more expensive than the Home Depot ones, but they will last a very long time, and work better, too.
Gene Gauss
>I've used bits designed to drill in glass.
Pete in Holland, MI
>The glass drills are a steel shank with a piece of carbide on the end that resembles an arrow head. Can get them at most hardware or big-box stores. Drill at 5-700 rpm, support the tile well on the back side, light pressure on the drill, especially when it breaks thru. Still not garanteed not to shatter a tile, but is your best bet.
Good luck !
That's what I use
Jack
Make it easy on yourself... *LINK*
John in New Mexico
>Use a diamond bit with water in a drill press. You can probably use them freehand too, I've never tried it. Light pressure, like drilling wood instead of metal. Cuts great, doesn't break the tile, you'll never go back to those carbide things the borgs sell.
I used to buy them at a local tool store in Tucson when I lived there. The link is the first one that came up googling, never done business with them myself. I think Kingsley North also sells little diamond bits, I have bought stuff from them, good outfit.
First google hit
