Computer problem
Computer problem
Computer problem
North of the Border
>Not sure if this site allows questions about computers. If ot, my apologies.
I'm a dummy when it comes to networking and wonder if any of you (or your computer friend) can give me an advice on this problem I'm having:
I can't surf the net with my laptop although I can download updates for my antivirus s/w (I have both wireless connection and local area network connection but none enables to go onto the Internet / or my email connection). The Windows diagnostic message says "Windows did not detect any problems with your internet connection over http or https but was unable to make a successful connection over FTP ... a firewall client running on your machine may be blocking the necessary ports. Anyone has any clue on how I should go back on surfing via Internet Explorer?
Two more pieces of info:
Warning on FTP: FTP (Passive): error 12029 connecting to ftp.microsoft.com: A connection with the server can not be established.
Same thing on FTP (Active) ... Could not make an FTP connection
More info: I pinged the computer ip address and it says transmit failed and error code 65. Loss is 100%.
Re: Computer problem
Bill Howatt
>you said "go back" does that mean it was working and now it isn't?
If it was, then what did you change/update that might have caused the problem?
FTP requires port 21 be open on your machine. Your email will use a different port if it is not using your browser (webmail). For browsing the internet port 80 is used. Funny that the diagnostic indicates all is well except FTP and you can't browse.
My first attempt would be to see how your firewall is setup - what is it allowing and not allowing. The other thing to check is your router to see if it has some ports blocked or internet access blocked - it may be called WAN (Wide Area Network), again, it is funny since the diagnostic indicates it is working and you can download AV updates although they may be coming in a different port.
Best I can do.
Bill
Preface with OT even though your title is clear
Bill Howatt
Re: Computer problem - Tks
North of the Border
>I can do msn (instant messaging) but I simply can't log onto any sites using IE or Firefox. I tried turning off the windows firewall but the outcome was the same. I reinstalled the Firefox and it didn't help either. Outlook express isn't working but since MSN (Windows live messenger) is working, connection (wireless or thru the LAN) should be the issue here. I don't use FTP for anything and have no clue why it'd affect my surfing. Anyone with more sugestions please send them in. Sigh!
Re: Preface with OT even though your title is clea
North of the Border
>Thanks. With do that next time. I suppose it means off topic(?).
Yes
Bill Howatt
Bill Howatt
>Do you access your ISP through a router? If so, make sure WAN access is not disabled or anything that might be blocking port 80.
