ADVERTISE HERE - FREE TRIAL
Help identifying casement window mfg
jess bunch
>I need some help in identifying the casement windows in a 30+yr old house. They are crank out thermopane and the crank handles are dark brown. I have removed one and can not locate ANY identifications any where on the frame, window, trim, mechanism, NOTHING. Any help will be appreciated. Yes I did check more than one. Thanks, Jess
Re: Help identifying casement window mfg
Roger Lance in GR, Michigan
>Good chance they are Anderson windows.
>Sorry..proper spelling is Andersen windows....also Pella made casements in this time frame.
>It would help if you post a picture of the hardware and any other parts that might be characteristic.
Andersen and Pella certainly made casements in that time frame. So did Caradco (Caradco?), Peach Tree, Better Built and several others.
Also, there was company called Truth that I believe made hardware and sold it to others but I don't think they made the windows themselves.
It might help to know what part of the country you are in. There have been dozens if not hundreds of local manufacturers, but only a few have nation wide status.
Al Stokka - Cambridge, Iowa
>Jess,
Do you need hardware (opening mechanism) or window parts? The hardware would likely not be made by the window manufacturer. Truth Inc was a large hardware manufacturer located in Owatonna, Minnesota. That address is quite a few years old.
If it's window parts you need, the only clue I have that might help is to look at the metal spacer between the glass panes. You may find the manufacturer's (either the window or the light) name there.
Al
jess bunch
>Thanks to all of you that responded, I will take a picture and try to post it tomorrow. I need to replace with same mfg if I possibly can. The house is a 4,000 sq ft stucco Mediterranean style, I have to believe the windows are top of line?? Jess
