Air Filtration Systems? Consumer Reports
Greg Haugen
>I'm looking for any feedback on Air Filtration systems (the boxed units). I'm in the market for one and I'm think about the Jet 1000B, Steel City's 3 Speed, or Powermatic's new one. Any feedback on these or others?
thanks in advance!
Greg Haugen
Re: Air Filtration Systems? Consumer Reports
>Most air filtration units are pretty standard commodity fare, so it may be hard to find significant differences in similarly powered units. I have a Delta that works great. I liked the gauge on the Steel City that tells you when the filter needs cleaning, sorta like a manifold vacuum gauge. Other than that, not much help here.
Anyone shopped these three units?
Bob in NE Ohio
>I have 2 of the Jet units in a 700sq ft shop and they seem to work very well. My son has a large grizzly unit in his shop and that appears to work well. As Ellis said they are pretty similar so price is probably the difference.
Good Luck
Bob
Sean Troy
>I have the Jet and It seems to work very well. I like the 3 speeds and timer function. Remote also. the outer filter is a common size that can be replaced with a borg bought one thats cheaper in price and better in quality.
Dave Bair, Eaton Rapids, MI
>I have the JET 3-speed. The remote seems to need to face the back of the unit (where the manual controls are) to function well. I can usually bounce the signal off the wall facing the back of the unit and get it to work, but not always. The remote may use an infra-red rather than a radio singnal.
My suggestion is to get the quietest unit you can; my JET's lowest speed is fine but gets too loud at the higher speeds to clearly hear a radio.
Timers?
>I picked up two of the earlier Delta models, right when they came out with the ones with the electronic timers. Because they were being liquidated at $60 I could afford to buy a $20 timer for each.
I'm not sure which ones have a timer, but it's handy to set it so that it continues to filter the air in the garage for an extra 30-60 minutes after I've gone back into the house.
Happy Woodworking!
air cleaners
les winter
>I have three: a Jet and two that I built.
The Jet sounds like one at the higher settings and otherwise works well. The two that I built, using good plywood, are somewhat quieter. Penn State Industries sells parts if you are so inclined.
I recommend the expensive washable pre-filters. Borg filters are not nearly fine enough to protect the expensive inner filter.
>I have a JDS 750 that I got on sale. The delay timer is very useful to leave the thing running for an hour or so after leaving the shop. Since I have either the DC (machines) or the shop-vac (sander) running, I haven't used the high speed, but it does a good job of reducing the Floating Fines.
Prior to this I used a pair of box fans with micro filters attached.
mm
Jim Dillon
>Greg,
I built my own so I have no experience with the others except an opinion that they seem to be simple devices all much alike. I have found having two speeds (low/high) and a timer to be useful for the same reasons stated by others. I would shop for price and those features. It is amazing how much dust they pick up. My 2 cents.
Jim
