Finish top and bottom or not.
RickS
>I'm replacing a badly cupping, poorly stained, poorly attached, poorly finished piece of nasty poplar half wall cap (builder installed) with oak. The piece is about 10 inches wide. In order to mitigate the cupping (and give it a little bit of a different look) I am laminating 4/4 flat-sawn red oak in a butcher block style 1 1/8 inch thick. Normally I would finish the bottom and top with the same number of finish coats to even out moisture absorption, but with this all now being effectively quarter-sawn with the largest movement vector being vertically oriented, do I need to finish the bottom with the same three coats as the top?
Re: Finish top and bottom or not.
Bill Tindall, E.TN
>I would still put one coat all around and add what ever you feel you need additionally to the top work surface. No matter what the grain orientation if the top gets wetter than the bottom, for example, it will bow.
