Thin Kerf for Splines .... Results
Joe Burke
>I'd asked a question a day or two ago thin kerfs for spline mitre work, and I thought I'd share what I found.
I looked for the freud blade Ron Knapp suggested, but was unable to lay my hands on one. Once I do I'm sure it'll work fine. In the interim, I stumbled onto a blade in Lowe's made by Irwin. It was for finish cutting plywood with a 7 1/4 circular saw. Hollow ground steel with 150 teeth. Yep .... 150. That's too many teeth, but it looked thin and for $9.00 bucks I said, what they heck.
I soaked it in lacquer thinner to remove a heavy coat of lacquer ... ran a diamond paddle around the perimiter to remove any burrs ... sprayed it with some dry lube and took off.
I threw the little box together from some scrap, and I probably don't have an hour in the entire thing. The only deviation from my routine was to change from my standard 10" blade to the 7 1/4" to cut the spline kerfs. I only used the 7 1/4" for the spline kerfs ... not the mitres.
The thickness of the sides is 5/16" and the splines were cut from 1/16" mahogany veneer I had laying about. The bottom of the kerfs looks pretty flat to me. I didn't do anything to the joints but sand and plane them flush.
The blade will work. Maybe not long term ... too many teeth. Time will tell.
Just explaining what I found. The pictures probably aren't great, but it's at least a visual. This pic just shows the big picture. Check number 2 for the close up.
Re: Thin Kerf for Splines .... Results
#2 .... close up
Joe Burke
>Again, I didn't fuss with this at all. If you're particularly careful I'd think the results could be as tight as you'd like.
All of this just in case you'd need to produce anything at this scale.
I do a lot of spline mitre work and having this option will help me quite a bit.
Re: #2 .... close up
>I read your previous post and thought you wanted the splines to go the other way, the ones that are sliced in at right angles after the the joint is assembled. (What are those? Keys?)
For this operation you could use a six inch or even five inch blade, as long as the arbor was the correct size. I used to have an even smaller blade that I tried on my shaper, but it was pretty scary. (About a four or five inch blade running at 10,000rpm) Lost my nerve on that one.
Looks like what you have is working though.
Ralph Turney
>I agree with you Barry, that's what I thought he meant also. Why all the hoopla over the size of keys that won't even be seen? Oh well.
Ralph
