200+ woodworking book reviews
brazilian woods
brazilian woods
brazilian woods
Walterboy
>I'm constructing a small landscape bridge for my backyard using ipe for the deck boards and cumaro for balusters and railings. Should I seal the ends of boards to cut down on the checking and if so with what? Also, I was hoping to stain and seal the wood to retain the dark color but I don't want to have to get into a time consuming maintenance routine every year. Does anyone have experience with these woods in an outdoor setting. The bridge will span an area where water runs underneath it and where there is considerable wetness during much of the spring so there is a real concern with protecting the wood from water absorption from the end grain.
Re: brazilian woods
Re: brazilian woods
Howard Norman
>I built a deck a couple of years ago using ipe. I used Ancholseal on all of the cut ends. Only with one board have I had any cracking. I assume that I did not properly prepare that board.
Howard
Re: brazilian woods
Re: brazilian woods
boardman
>Ipe and cumaru are 2 of the densest woods around, and water absoption is not really a concern. Ipe's been used on Atlantic boardwalks it's so resistant. Here's a link to an oil based product:
http://www.ipedepot.com/messmers.htm
There isn't a yearly maintenece issue even when it's left unprotected. You can sand it down after about 3-4 years when it may grey a little, but it's basically like concrete.
Be prepared to predrill everything and to drill a little bigger than the recommend or usual size for the screws. Ipe will snap screws like toothpicks.
