Doors Hitting Drawer Slides
Howard
>What do you guys do to protect the inside of the cabinet door from being scratched by the drawer slide when the drawer is pulled out? Thanks.
Re: Doors Hitting Drawer Slides
>nylon bumper dots applied to the drawer body at the front corners
Re: Doors Hitting Drawer Slides *LINK*
Jim Dillon
>Howard,
I assume you mean a door that won't fully open enough because of a door hinge choice, or a drawer slide that is mounted flush to the inside of the cabinet, or a cabinet that is flush to a corner wall thus blocking the door from fully opening. If you haven't already built the drawers, then off-setting the drawer slide on the door hinge side might work. Certain styles of European hinges that allow door openings of 120 and 170 degrees minimize door/cabinet side interference might be useful. Downloading the pdf file associated with the Blum hinge will give you a diagram of the hinge/door/cabinet placement that might be helpful. Just some thoughts.
Jim
Blum Hinges
Drawer Bumper *LINK*
Jim Dillon
>Howard,
I assumed you were in the process of building the cabinet. If it is already built, here is something designed for what you described.
Jim
Fast Cap Drawer Bumper
