flattening veneer
McKay
>I have a beautiful walnut veneer burl that needs to be flattened some. I have glycerin and a spray bottle, but I am unable to remember how much of each I am to use to flatten this out. Any help? Thanks
flattening veneer
McKay
Make sure you use Distilled Water
Re: flattening veneer *LINK*
Bart Goldberg
>Check out this link to the Joe Woodworker site for all the info you need about flattening veneer.
Regards
Bart
Flattening Veneer
Homemade veneer flattener
>I question Joe's recipe for homemade flattener. He says the age old recipe is to use three parts of water to two parts of yellow glue to one part each of glycerin and denatured alcohol. That is a huge amount of glue. No wonder he says it is messy and seals the cells. The formula I learned from various gurus many years ago is simply an 8:1 water/glycerin mix. I've heard some people recommend a small amount of liquid hide glue in the mix, but I've tried that and didn't really see any difference.
Age old recipe?
>can't be much older than WWII no can it.
The ratio Ellis gave is good, use distilled water, with the addition of the hide glue the veneers are pre-sized and much easier to get a good hide glue bond.
Stephen
Re: Age old recipe?
>David Marks did an episode on his Wood Works show about this. Involved a concoction of water and glycerin and ....?
Also, he had a press and used paper and window screen. Might be worth going to the DIY network site and looking it up.
Re: Age old recipe?
Tony - Memphis
>That's basically what I use for mahogany crotch. I got the recipe I use from Vacupress's Daryl Kleil. It's on his web site or other web sites. Work's great. I didn't use distilled water, but maybe I just got lucky with the water we have here.
Tony
The addittion of glue
Lee Grindinger
>Glue is unnecessary if the veneer is to be used very soon after the flattening is done. I've used PVA in the solution containing glycerin for a larger lot of veneer, much of which was for stock, so I wanted it to stay flat for months and years. The glue accomplishes this long term result, glycerin alone will flatten the veneers for a while but the crinkles will return without the glue.
Good advice on the distilled water, a bit of iron in the water will ruin the veneer with rust stains.
Lee
Re: Liquid hide glue
Howard M
>I was told not to use liquid hide glue as it may result in mold forming on the veneer in storage.
Howard
Probably true, but...
>...every time I flattened veneer, I used it right away (well, in a couple days when all the water had been sucked out by the newspaper). I didn't think the glycerine was effective for long enough to store the flattened pieces for any length of time and stay flat. I'd like to hear more about this.
Not likely
Lee Grindinger
>Mold needs moisture, around 18% or so, to thrive. That's pretty moist by most shop's standards.
Lee
