router table fence
router table fence
router table fence
les winter
>I'd be interested in knowing what you-all use for router fences.
I just finished up a few kitchen cabinets for my laundry room as a warm up to redoing the entire kitchen. The coping and sticking of the doors on my router table wasn't too much fun. The table top is big and flat, and the router is big Porter Cable. The fence is from hunger.
It's an "L" made of oak which is pretty straight and pretty flat, but it's just no fun to fool with the two clamps to hold it down, two more to hold the bit guard, more to hold feather boards...
I enjoy using good tools.
So I started looking about and I like the Jessem. But it goes against my grain to spend 200 bucks on an extrusion and few brackets. A nice length of 4x4-inch 3/8" thick aluminum angle costs around $80. A little saw work and I'd think I would be ok.
Any creative input would be appreciated.
thanks
les
Re: router table fence
That's what I did......
>The Metal Supermarkets sells steel and aluminum by the pound here.
1/4" angle aluminum is cheap and really easy to work with.
I have a diagram on my www.happywoodworking.com website that shows how I used a holesaw in the drill press to cut out two offset holes in the middle part of the angle to have enough height and depth for the router bits. Look for "Shopmade router Fence" in the center of the home page.
Hope it helps.
Happy Woodworking!
Roger Lance in GR, Michigan
>Les...by all means, I'd advocate making your own...after all thats sorta what this hobby is all about...using your own abilities to design and build things...for my fence, I used 90* aluminum extrusion to which I attached bb ply which was then covered by laminate to get things slick...design in dust collection make use of the "T" shaped router bit to cut a channel for mounting feather boards etc and you are on your way to a pretty good fence.
>Greetings Les,
My first router table had a home made fence. It is in effective use today in my son's business, along with my first table. Had there been a readily available length of aluminum right angle stock, I probably would have made another home built fence for my current cabinet and table. However, the PSI fence looked pretty good, and didn't cost as much as the JessEm. I went with that and am very satisfied. I have to admit that its better than what I made first from wood.
George
Robert R Clough - Thorncraft
>Before you do anything, please check out the latest Popular Woodworking (April, 2008, #168). There are two articles, one by Charlsworth and the other by Lang. Charlsworth takes several pages and goes into excellent detail on what he says works. Lang makes his point in fewer pages, but equally well.
I have had a purchased fence from, I think, Highland Hdw, purchased many years ago. It was movable and adjustable for drift. I no longer use it. I prefer to use a point fence as easier to set up and use.
Larry Clinton At Frankfort (Central)., Indiana
>Les, I have a BenchDog, its around 34" long has 2 movable inserts (replaceable MDF) & shims for offsetting the out-feed fence. It clamps very easily to my table, easy to slide and adjust in thousands of an inch. The sliding inserts allow you to adjust so the opening fits the bit. It also has built in guard and dust collection. The fence is at an accurate 90 deg to the table and high enough to edge route items without tilting them. I found it at an auction, new in the box - think I paid $30 for it - know they are a lot higher online, but if mine was stolen, I would spring for a new one.
Re: router table fence *LINK*
pecker
>My first one was homemade, but eventually I got the one from MLCS. It's under $100, quite tall, and has dust collection and T-tracks for featherboards. It comes with some mounting block/clamps, but I added T-bolts and T-track to the table as an improvement.
http://mlcswoodworking.com/shopsite_sc/store/html/
Re: That's what I did......
les winter
>Nice web site. If you had to do it over again, would you go to 3/8" angle, or was the 1/4" really thick enough?
thanks
Les
Tight-budget router table fence
Bill Hylton
>The aluminum angle certainly will work, but wow!! 80 bucks?! That's almost what I spent on materials for an entire router table, including the fence. (See the current issue of AW magazine.)
I've always used wood-based fences on my router tables. That is, gluing two boards together to form the angle. Since it has no metal in it, I have no reluctance to re-dress it from time to time on the jointer to ensure the face is square to the bottom.
Years ago, I bought a pair of Vise-Grip c-clamps that I've used to secure router table fences. But for most of the RT fences I've made, I band-saw a pair of L-shaped blocks that mount to the fence with carriage-bolts and big plastic wing-nuts.
Featherboards? I've screwed a pair of shopmade 'boards to a cleat. Two F-style clamps secure it to the RT fence, and it provides downforce on both the infeed and outfeed sides of the bit.
To me, this kind of fence is just fine. Strong, durable, micro-adjustable, easily detachable...and inexpensive.
Bill
Good point
>I thought he said $8 for the aluminum, not $80. I usually get nice pieces of aluminun for $6-$15 for this sort of thing at Metal Supermarkets
Happy Woodworking!
Re: Good point
les winter
>Well thanks for the info. Bill: I bought two of your books and enjoyed them.
I know it sounds nuts, but this thing has taken on a life of its own.
The recommended metal company had no on hand stock in the size I wanted. Grainger did. In 3/8".
So that's how I decided to go.
And I appreciate all of the fine advice.
Thanks all.
Les
charlie belden
>Unless you enjoy making jigs and sleds and enjoy working with "make do" things, just bite the proverbial bullet and get a precision positioning, replacable zero clearance insert Fence System that's designed to work as an integral system, especaily since you a) like good tools and b) have a complete kitchen worth of cabinet doors to do. Cope and stick (and probably raised panels) require some semi-tricky set ups - for each bit. And since there are at least two bits required you'll lose one set up in order to set up the other bit.
There are two such "Systems" on the market that I know of - the JoinTech and the Incra. I have, and have used, the JoinTech Cabinet Maker System - for all sorts of things, including Cope & Stick plus Raised Panel. It has special plastic inserts which are easy to have the bit cut to amn actual, not "close to" zero clearance and easy to replace, or reinstall - and aren't very expensive. The fence is hollow, square extruded aluminum with channels for stops and hold down - both handy to have - and has a dust port on one end for dust extraction.
What really makes the system handy is the fence positioning method - which allows dialing the fence foreward or back in Thousandths of an inch - with click stops you can count if you don't want to read a scale - which it also has. AND - it has a top and bottom lines vernier and sliding tape which allow you to postion or repostion the fence to previously used location quickly and pretty accurately - dial in or out for REALLY accurate postioning.
If you're going to do a kitchen worth of cope and stick doors that alone would justify getting the JoinTech or Incra. All the other things it well enable you to do will be FREE. What more could you ask for.
At least check out www.jointech.com and have a look at the Cabinet Maker System.
les winter
>thankyou Charlie and everyone else for the good advice.
regards
Les
del schisler
>here is what i use Their are 2 different fence's 1 fence is off set infead and outfed is I belive 1/8" so that the board come's out right I also have the router table They have lot's of item's
http://us.oak-park.com/catalogue.html?list=TF--&product=F016
