stopping 2 drawers being extended at once
Ian (in Sydney, Australia)
>I'm about to start building a china storage/display cupboard and want to prevent SWMBO pulling out two drawers full of plates at once and causing the cabinet to topple.
I've got a recollection of seeing somewhere an arrangement of rope and pulleys that connected to the back of each drawer in a chest of drawers that prevented a person extending more than one drawer at a time.
I think if you tried to extend a second drawer, the rope and pulleys would pull the first one back in, but I'm not sure.
can anyone help?
also posted on hand tools
Re: stopping 2 drawers being extended at once
NickB
>I think there was one of those reader's tips in FWW on this-IIRC it had screw eyes in the back of the drawers, with a rope running vertically and fastened to the case. The rope was just long enough for one drawer to be pulled out, but if you pulled out a second drawer it would start to pull in the first one. You might also look into the mechanisms for file cabinets-they have an interlock that only allows one drawer to be opened at a time.
Hope this helps,
Nick
Just nail it to the wall
Interlocks
>When I was designing contract furniture, we had to meet BIFMA standards, which included drawer interlocks for file cabinets. Usually, these are flat strips of steel that are mounted in shallow vertical grooves in the cabinet side(s) with studs that interact with molded plastic blocks attached to the drawer side(s). When you pull a drawer out, the corresponding stud is raised up and the other drawers are prevented from opening. I have not shopped for these things at the retail level, but I would imagine that CSH, one of our major sponsors that specializes in commercial cabinet hardware, could point you in the right direction. Woodcraft and Rockler, two other major sponsors, also may be able to help.
I like the string idea, though. Sounds like the low-tech way to go.
Ellis Walentine, Host
tether
Bill Tindall, E.TN
>Really, tethering it to the wall is better than some annoying rube Goldberg drawer arrangement. It will take but a small tether to prevent toppling. Design will help too. Make it adequately deep and well supporting feet.
Bill Hammond, Oregon Coast
>Years ago I took apart a cabinet that was built prior to the civil war. The purpose being to clean a mess that was made by some creatively destructive children. The cabinet had three deep drawers across the front. An interlock system on the rear of the drawers prevented more than one being opened. As I recall a wedge on the rear lifted up a locking bar. With the center wedge removed the bar dropped down locking the end drawers and with either end wedge removed the bar tilted with the far end going up to lock and the middle point down to lock. It really was rather simple and if you were to play with the idea I am sure that you could duplicate it. The mechanism only required about 2 inches of space at the back of the drawers. The disadvantage of the device was, you could open two or all three drawers if you pulled them at the same time. Took me about thirty minutes to figure that out.
Bill,
who believes that if cabinet makers made UI's computers would be easier for most people to use.
Mark Katz (Boston)
>Although I see the need for them, these kind of mechanisms have always worried me. What if the mechanism jams (or the string tangles) and you can't open any of the drawers?
Best to provide some kind of access hole in the back to unjam or untangle.
>One might think of them as job security ;)
Thanks everyone
