Does anyone know of where I can get plans or instructions on how to make sculpted seats for some stools I am about to start. I have been planning some stools for our kitchen and I want to make them with sculpted seats. I have not got a clue on where to start or how to go.
Any help you can give would be greatly appreciated.
Do you want to make round seats with a dish in the middle?
Do you want to make a "saddle" style seat?
Are these stools going to have backs?
I usually start with a 2" thick blank. For a "saddle" style seat on a stool, I typically draw a centerline from back to front. I then draw a line about 1.5 to 2" from the edge on the "back" of the stool covering about 1/3 of the back (centered on the centerline). I then draw two curves starting from the "pommel" in the front where the centerline touches the edge. These curves go to down to 1" from the top at about 1/6 the circumference and then come back to the top edges near where the back curve ends. I then drill 3-4 depth holes to about 3/4" about 1.5" from the back line.
I then take an angle grinder with a tungsten carbide "donut" and carve out the bowl of the seat (leaving just the front pommel on top). I take a drawknife and "break" the edge down to near where I drew the curves on the front. I refine this with my spokeshaves. I then use my travisher and chair pull plane to smooth out the rest of the bowl and match the sides on either side of the centerline. After I am happy with the roughed out seat, I start sanding.
For a round dished seat, I just drill the 3/4" depth holes in the center and carve out the center bowl. I draw a line about 1" down all around the seat edge and "break" the edge with my drawknife and spokeshaves. I then smooth and sand.
Would love some pictures. That is about the process I was thinking of. I just guess I needed to hear it confirmed. Just send pictures to above e-mail address unless you want to post them here.
>also not as deep. Basically shallower. I like the basic design, but I wasn't as happy with the grooves as I thought I'd be - I'm thinking of making them shallower the next time I do a run of these.
>When I make my Maloof style rockers I drill holes to a certain depth(depending on seat thickness) to act as limits when I grind the seat out. I use a Kutzall grinding disc as shown in the link at the bottom.
End result is something like this...Once you reach the depth limits and use the sanding discs it comes out pretty even.
>I've only made one. I did not have any of the traditional tools or a angle grinder or Kutzall. No wood carving chisels or scorps.
I made the one seat out of Osage (harder than Woodpecker's Lips) Orange. I cut the saddle with a Radial Arm Saw. I glued up the blank out of 5/4 stock so that it was shaped like a shallow "W". Learned that from Sam Maloof, but he uses their stock. I was making a baby's high chair. I did the sculpting in three setups on the RAS. I Clamped the blank to the table and turned the saw to the rip position. Then I lowered it about a 1/16" and dragged it sideways across the wood. Lowered it again and did it over and over. Cut the leg "troughs" out this way in two setups and then rotated the blank ninety degrees and cut the rump part out. Pretty rough, but then I sanded it into submission. Came out beautiful. Used a 5" random orbital sander. The process was sort of like cuttign cove moldings on a table saw.
The chair has been returned to me for repairs. The seat is fine, but the young owner kept pushing it over on a brick floor and it has several broken parts. Osage is hard but brittle.
