Honey Locust (thornless)
Paul T
>Hello All,
Some what I think are thornless honeylocust trees are going to be coming down by my office building. Trees are around 14" diameter. I've never used/seen honeylocust being used for woodworking other than a reference on the internet to the Cherokee Indians using it for bows. Is it good for anything?
TIA,
Paul
Re: Honey Locust (thornless)
andrew nistock
>Paul,
What you may have there is a black locust. Yes they have a lot of sweet smelling blossoms in the spring and the honey bees have a good time with them. Around here we have a lot of them and we use them for fence posts. Some use the lumber for decking material since it is rot resistant. But, be forewarned, when it is seasoned it is almost as hard as steel. If it is honey locust I know nothing about it. :-)
Andy
Ray Binnicker
>If it is Honey Locust do all you can to convince the folks who have the authority to dispose of them that they are totally useless, and then offer your services, free of charge, to remove it all. (:-)
Ray Binnicker
Robert R Clough - Thorncraft
>It is an interesting wood if, if you can work it. Years ago (50?) I tried to cut down a small HL Tree, probably 6" in diameter. All I had was an axe. A friend finally came over and used a chain saw.
Re: Honey Locust (thornless) *LINK*
charlie belden
>Still haven't found out if this is honey or black locust but it sure has a very active grain. The top of this mortising machine cabinet was almost too interesting to bolt the machine onto it, Six or eight coats of hand rubbed shellac popped the grain a bit and really made covering it up more difficult.
Honey or Black Locust
Larry Clinton At Frankfort (Central)., Indiana
>Paul, I have attached a picture of a bathroom Vanity my son & I made a o couple of years ago using Locust. The local sawmill however, mixes both Black and Honey Locust in the same bin (didn't realize this until we had the lumber home). We finally identified the woods - Black locust has Tylosos (sic)(like White Oak) - Honey does not (like Red Oak). Easy to sort, an inch or so cutoff will allow you to suck air or water through wood without the tylosos (Honey locust). The Honey locust we used had a yellow cast with pink to red tinges running through most of the boards. The Black locust is more of a grey wood with some green casts (both stained well with oil stain). Both are very hard - although we had a lot more tearout with the jointer, planer & router with the Honey Locust. Both have chatoyance - with the grain appearance varying greatly dependent on the viewing angle. Both varieties are very durable and will outlast White oak, Cyprus, and todays redwood for outdoor applications. I really like the wood it finishes very well and I think has better grain than the Oaks. My son has told me he read that they are now growing plantations of locust in Europe for furniture use. I intend to use much more of the wood, since I now have a Griz jointer and Yorkcraft planer with the spiral heads. I have ran some badly gnarled Honey locust through them without tearout.
Ron Jackson
>Honey Locust is a great wood. Grain differs from black Locust however main difference is color B locust tends to the green side and Honey has a pink cast. Too bad it comes from small trees.
Dave Bair, Eaton Rapids, MI
>Chances are that the trees are a cultivar called Shademaster locust. They are frequently planted in urban environments because they're thornless, don't produce seeds and their leaf-fall requires no raking or collection. Having said this, I cannot tell you if they are of any value as lumber other than what others have said here in this thread.
>Honey locust is valuable to wood turners. I got some recently and it has great figure. (The black locust I've cut and sawn has been pretty bland in comparison.)
Robin Corell in Atascadero, CA
>As it has already been mentioned it can be almost impossible to tell for sure what type of locust you have until you open it up. I have attached a pic of a pair of stools I make a while back out of black locust. It works well and takes a beautiful finish. The color will continue to develope and deepen to a warm rich yellow brown. When freshly cut it has yellowish green tones but the green tones down and it warms up a great deal. Many prople thought the stools were made from some tropical species. It turns nicely but tends to splinter a bit on the side grain when turning dry. I have carved it with reasonable results. It is a bit hard and it would not be my first choice for a carving, I wouldn't reject it for a project that needed a bit of carving either.
I mill all my wood with a chainsaw and tend to mill everything 2 1/4" thick. I have had very good results with the black locust I have milled this way. I have a friend who milled some at 4/4 and it warped pretty badly. Based on this I would recomend going thick and planing on resawing. This is all based on air drying and goes out the window if you have acces to a kiln. Compared to many harwoods black locust has very little sap wood and it in my opinion is very usable. Black locust also takes longer to dry than any other wood I have ever milled. I can usually usualy air dry black walnut in about 18 months and black locust can take almost 3 years. I live in central Ca with a relatively low anual relative humidity so your times may vary greatly. Once dry the wood is very stable and will not move significantly, but if you resaw or cut it in any way before it is dry it will behave like it is case hardened.
On the west coast all hard wood prices tend to be quite a bit higher than on the east coast. if you can find a local supplier and see what they sell locust for and then estimate the yeild with the lumber estimater on the wood web site you can get an idea if it would be economicly profitable to have the wood milled. If you will be milling it yourself then I would say go for it. Be prepard though as black locust is very dense and one of the tougher woods to mill.
Robin
Jim Dillon
>Paul,
My wife and I have laid around 400 square feet of a mixture of honey and black locust on our cabin floor. From leftovers, I have also used it in building a bathroom vanity, several storage cabinets, and a small jewelry box. It also makes great drawer and miter-slot runners. I think it is a very attractive wood. It is indeed hard, but seems to sand and finish well. Like others have suggested, I would take a chance and get some if you can.
Jim
