Jessen Mast R Lift Problem
>Good Afternoon Friends,
Has anyone had a problem with the Jessen Mast-R-Lift insert rings? I've been using the lift for a little less than a month, and the insert ring which had come with the lift has been used to satisfy most of my current router needs. However, I had to swap out and install another ring to accommodate a larger diameter bit, and found out the insert ring is frozen in place. Jessen supplies a wrench which incorporates two pins which are accepted into corresponding holes in the insert rings. I tried tapping the wrench with a wood block and dead blow hammer to loosen the ring, but the ring wouldn't budge. I squirted some penetrating oil into the ring circumference without success. I verified I was tapping in the correct direction to loosen the ring, and then one of the prongs broke out of the plastic wrench, and took off for outer space. The prong is roughly the size of a pencil eraser, and I can't find it in the shop. This renders the wrench useless. The insert is still frozen, and the Jessem Technical person was unavailable to address the problem when I called. Hopefully, they will call me back. Anybody have any comments or ideas?
George
