Veritas - Innovation in Tools
Thin Kerf for Splines
Joe Burke
>I'd love to be able to cut some thin kerfs for splined mitres using my tried and true tablesaw sled. The farther away from 1/8th I get the better. I've looked at the specs on some thin kerf blades, but I wonder how accurate those numbers (.087 for instance) are?
Anyone ever had anything ground for this purpose?
How about a 6" circular saw blade? Do they even come with a 5/8" hole?
I'm just spit balling before experimenting ....
Re: Thin Kerf for Splines
John McGaw
>A few years back I had a wild idea that putting a couple of small circular saw blades made for a battery-powered saw on my shaper spindle with a suitable spacer between them would make for a really great tenon cutter. Of course the hole in such a blade is the wrong size for the task so I checked with a few local sharpening services and the ones that said they could perform the job all quoted prices which exceeded the price of the blades by a considerable margin.
Howard Acheson
>For most blades, the manufacturer's specs are right on as to the thickness of the carbide tip. However, if your blade is not exactly parallel to the miter slot and the fence not exactly parallel to the miter slot, the blade may cut a somewhat thicker kerf. So be sure your blade is exactly parallel and that you use some type of hold down to keep the piece being cut firmly against the fence.
The way to be sure the splines fit properly is to first cut the slots and then size the spline thickness to fit properly.
There is no reason you can't use a 7" or 7 1/4" circular saw blade.
7" blades on a 10" saw
Lee Schierer - McKean, PA
>The only problem with using blades for a 6" or 7" saw on your 10" saw will be the total cut height they will provide. The arbor only raisesup so far anf with a 10" blade you get about 2 to 2-1/2". A 7" blade is only going to give you about 1/2" to 1" depth of cut.
Lee
Ron Knapp
>Freud sells a 7 1/2" very thin kerf (.59) blade that I have used for cutting banding. The blade should work fine in a nrmal tablesaw. If you happen to have a Sawstop you are out of luck as even bypassing the safty controls won't allow this blade to work in the Sawstop.
The following lenk should give you some more information:
http://www.mcfeelys.com/product/DIABLO-FINISH/freudreg-Diablo-Finish-Blades
Re: 7" blades on a 10" saw
Ralph Turney
>I'm not sure what table saw you use, but on my model 66 I can cut over three inches deep the last time I looked. But you're right, using a 7" blade still leaves you with a pretty shallow cut of a little over an inch and a half deep.
Joe Burke
>That's the ticket ... or something like it.
I tried a 7 1/4 I had on hand, and for the small mitres I'm cutting it'll provide ample blade height, even with the deck on my sled included. It's been so long since I used my circular saw I didn't remember it took a 7 1/4" blade. The blade I tried was too heavy and produced a kerf still over .100, but thinner blades should give me something a shade over 1/16th ... which is just right.
I can even lay hands on one locally ..... even better.
not so!
Bill Tindall, E.TN
>I keep a 7 1/2 in blade on my Delta 10" saw. Vastly safer to use as it won't kick back or throw things. It will cut just shy of 1 3/4" deep. They can be had in a great variety of kerf widths. I use the most narrow I can find.
Charles M
>Why do you say that it will not work in the Saw Stop saw?
Charles M
Freud America, Inc.
Charles M
>Oh yeah, you were referring to the smaller diameter blades. Duh!!
Scott Whiting - Glendale, AZ
>Small thin kerf blades work fine on most 10" tables saws. You are talking about exposed joinery here and just wait until you try and find on that is flat top grind. :-)
Two option here: Have a blade reground to flat top or make your splines on a router table with a slotting cutter which cuts 1/2" deep which is probably not enough.
Laminate flooring
>Since the laminate flooring (some fort of aluminum-magnesium topcoat) produces srpaks when I cut it using my 12" CMS and that blade dulled so quickly, I used an inexpensive 7.25" blade in my Unisaw when cutting the flooring.
I often use a 7.25" blade in the Unisaw because for thinner material, those blades are so economical.
Happy Woodworking!
