Tiger Maple Blanket Chest (PICS)
David Yoho
>This is the tiger maple blanket chest I recently completed. During its construction I tried many new techniques and will continue using most of them going forward. This chest features a beautiful antique look from the rustic black iron hinges to the multi-colored dyed finish and the ogee bracket feet. The main wood is curly (tiger) maple and I also used poplar for the web frames, aromatic cedar for the chest's bottom, hard maple for the back panel of the chest, and quarter-sawn sycamore for the drawer boxes. All of the hardware is from Horton Brasses.
This shot shows off some of the nice figure with the lid up. I applied eight coats of Waterlox Original Sealer/Finish (medium sheen). The chest consists of two cases, which join where the waist molding is located. I cut the through dovetails using my new Leigh Super jig. I actuall used more hand tools on this project than ever before. Those I put to work included several planes, a spokeshave, cabinet scraper, coping saw, chisels, rasps, and rifflers.
The inside of the chest features a tongue and groove aromatic cedar bottom that simply rests on top of the upper web frame. It is held in place with a curly maple quarter round molding that I attached to the chest with some 23-gauge pins. The molding is back-mitered for a snug fit and the look of a true mitered joint. The reason I installed the bottom this way is if someone has the chest locked and has lost both keys, it's a simple matter to come from underneath, pop the bottom out, and remove the screws holding the lock. This would be an easier repair down the road than the alternative! The cedar can also move independent from the case, which is always a good thing.
One thing I did new on this project was to finish the inside of the two cases before joining them together. Once the entire thing was assembled (minus hardware), I applied additional coats of Waterlox to complete it.
The drawer boxes are 1/2" quarter-sawn sycamore and I hope you can see some of the figure in this shot. The bottoms are 1/4" thick with the grain running horizontal front to back. The bottom floats in the grooves but is held with a single #4 screw centered in the back rail. The bottom is slotted in the center for the screw so it can move. I dovetailed the drawer box front and back. The front of the drawer box is a piece of 1/2" tiger maple. The false drawer fronts are 1/4" tiger maple that I glued and clamped to the piece on the front of each box. The end result looks like a rabbetted dovetail joint in 3/4" stock but without the hassles of really doing it.
Thanks for looking,
David
