OT: Garage door opener help please
Mike Schwing from Md.
>Original door opener broke about 2 weeks ago. It was a 1/2 HP Chamberlan unit. The motor shaft bearing broke free from its weld and the pulley was wobbling, throwing the chain. I replaced it with a new unit from Home Depot, identical in most important respects, but more powerful at 3/4 hp.
It worked great for about 2 weeks. I did not need to adjust the force setting, but the travel did require some fiddling. No big deal.
Then it stopped working properly, it would go about 2/3 down and reverse backup, the lights flicking on and off as it if encountered an object in its path and reversed - no such objects. I was able to put my hand on the door, and add a little force, the door would close fully. I disengaged the door from the trolley and am easily able to open and close it manually - no real sticking points anywhere.
The weather did get suddenly extra cold right at the time it stopped closing fully, and I figured maybe things were getting a little frozen, so I adjusted the force setting - all the way to full, with no change in results.
Then I regreased the chain and the tracks with fresh lube, and the door closed fully, once. Only once.
What am I missing here? Any ideas? Help appreciated. Thanks.
Re: OT: Garage door opener help please
Jason Roehl in Lafayette, IN
>A few things to check:
The safety beam--it may be normally at the fringes of alignment, but the cold affected the metal brackets enough to pull it out of alignment (along with the vibration of the moving door).
The C-channel tracks on the sides of the door--again, may work normally, cold makes them too tight for the opener.
The operation of the spring(s). Make sure they are doing their job and that the lock pulley(s) is(are) indeed locked to the axle. (Standard disclaimer about the springs--they can be deadly, so don't loosen those square-head bolts if you don't know what you are doing.)
It might be worth $50 for you to have a garage door pro take a look at it (might be more in your area).
Use the manual to set the force. My experience is that it's not an intuitive system--there are specific steps to follow.
Jason
>I'm not an expert but most of these units have two adjustments. Sometimes labeled Down force and sensitivity. They Sensitivity one (I think) has to be adjusted so that it has enough sensitivity to stop when it hits something but not so much that it stops at every bump and grit in the track or mechanism.
It is also my understanding that you should turn these knobs very slightly. Not from NOON to 12:15 or 12:30, but more like from noon to 12:05 or 11:55 or even less. Start with tiny adjustments. If you make gross adjustments you may get so far out of whack you will never get it right. Sounds like you are close anyway.
And follow Jason's comments also.
>Thanks guys. I found some more information online at the manufacturer's website that leads me to think it is nothing more than the safety reversal sensors being out of alignment. That would be nice! I do recall accidentally kicking one of them not too long ago. Will report back.
Sensor alignment
Tim Greif - West of Chicago
>Something in the sensor path, or misaligned sensors, will generally let the door only go about 1/4 of the travel, then reverse. When this happens, the light on the unit will blink 10 times as a diagnostic indicator (for Chamberlain, Craftsman or Liftmaster units). I've rebuilt a few of these things. My BIL has his own garage door business and I get some of the "take downs" which are malfunctioning units that will cost his customer more to diagnose and fix than to just replace.
For what it's worth, I've replaced the bearing/gear assembly in both my 18 year old Craftsman openers (made by Chamberlain). The kit's only about $30 and it's an easy afternoon fix.
Most folks who have troublesome electric eyes just tape them to a short piece of wood pointing at each other and screw it onto the ceiling above the door opener. And don't rush to criticize me for recommending this. My 18 year old door openers didn't even have the feature. I'm no less safe than the newer ones.
Re: OT: Check the wires too
Brian in Brighton
>A little four legged critter decided that mine looked yummy. So some of the wiring went into his tummy.
One sensor dead. So I had to disassemble it and resolder the wires into the circuit board.
FYI: If you decide you really want to chew thru some wires on the garage door sensor be sure to chew thru them less then 1/8 inch from the strain relief on the sensor. The owner really hates that. :-)
Brian in Brighton
Ray, SW Ohio
>I had a similar problem with my garage door. It would only go 1/2 way up. Sprayed a little wd40 into the wheels and problem solved. I guess there was some moisture in the bearings of the wheels.
Humity and/or alignment of the planets
>Sometimes we have an issue like that.
If the garage is still cold from a really cold night, but it's warmed up and gotten a bit more humid outside, when we open the garage door I think we get some condensation of the sensor lense.
Also, I've found that as the seasons change and the position of the sun changes in the sky, there is a time in the spring and fall that the sunlight hits the sensor just right to cause it to malfuntion. Placing the garbage can in the right spot to block the sun seems to help.
Garage door openers sure can be termpermental sometimes.
Happy Woodworking!
I see this every winter
Lee Schierer - McKean, PA
>Every time it gets really cold, I have to lube the rollers on my garage door or the door witl start down and then go back up. The second time I hit the button it will generally go all the way down. The cure each year is to spray each roller with 3 in 1 oil and the problem goes away with no other adjustments. Basically my opener reminds me to lube the rollers once per year.
Lee
Re: Sensor alignment
Tony - Memphis
>Mine do that all the time. They aren't attatched very well and tend to get kicked and knocked around. They are easy to set back in alignment. Oh, its a Liftmaster - ~10 years old. I have replace the gear once too. I try to grease it once or twice a year now. I have kept the sensors in place for liability and for whoever owns the house next, neighbors kids and animals, etc. Mine were put in so poorly, it has been a challenge! This has got to be the loudest clankiest garage door opener ever made. I grease, I tighten, etc. Still loud. Oh well, its not that big of a deal to me. Actually, I'm impressed that it has lasted this long. Nice thing is that it is easy to get parts for. Even the local sears parts depot has them.
Tony
Dennis Yoder
>Mike, Had the same problem last year and after many trips up and down the ladder it was the force sensor that needed to be increased a bit. Dennis Y
On noise...
>I haven't messed with mine at all yet, but our house is a bi-level (garage is 1/2 of the basement, front door entry is halfway between the basement and main floor). Anyway, the opener is roughly centered underneath the doorways of the three bedrooms, so you can imagine how loud it is in the house. From what I've read, the single biggest thing you can do to reduce noise is to de-couple it from the ceiling. In other words, a typical installation causes it to be a transducer that uses the whole garage ceiling as a sounding board. The noise doesn't bother me, though, because I am usually last to bed and first up, and want to know if someone is coming or going anyway.
Jason
Noise solutions......
>Our garage is directly above our master bedroom. With a wife who recently became a first time mother, we discovered how noisy the garage door opener was. So after replacing the chain drive, with a screw drive opener, we replaced the rigid hanging brackets with rubber hangers and loosely fitted steel-cables for extra safety.
Isolating the garage door opener from the ceiling in this manner did wonders for the noise solution, but it was nothing compared to the solution we found a few years later when we got a Wayne Dalton iTorque opener. Instead of hanging from the ceiling, the whole opener sits on the wall above the door, and controls the torsion bar, not the actual door.
Now THAT is quiet.
Happy Woodworking!
Interesting house design
>"Our garage is directly above our master bedroom." Is this a typo or the actual design. How was it done? Basement bedroom or 2'nd floor garage?
lee
Could be...
>...a basement bedroom. In all the houses I've been through to paint, I have run across one where there was a basement under the garage. The garage floor was, IIRC, concrete beams in a T-shape or TT-shape.
However, I think Mark must have made a boo-boo, as I would think that a garage door opener mounted on the ceiling of the garage would transmit much noise to a room below the floor. ;^)
Jason
Spider web!
Mike Schwing from Maryland
>A spider web on the bottom of the garage door had caught a bunch of leaves and detritus. It was tripping to sensor when it got within a foot or so of it, and the door was reversing.
All better now! Thanks folks.
Oh what a tangled web we weave...
>Amazing how simple the solution is sometimes! Thanks for the chuckle--I needed it--I just finished my federal tax forms as a self-employed person...and it's too late to drink when I have to work tomorrow...
Jason
Ooops.....
>Yes, I meant to say the garage is directly BELOW the master bedroom, or that the master bedroom is directly above the garage.
I got the words all muddle-mixedup.
Happy Woodworking!
