Sliding dovetail or mortise & tenon?
>I want to make a couple of rolling chairs. I was planning on five "feet" with casters.
I was thinking gluing up a center out of 8/4 (to make it about 5 or 6" in diameter) and rounding it and then cutting five flats with my jointer. I would then attach the "feet". The "feet" would be 8/4.
I was thinking about cutting large sliding dovetails in the flats and on the "feet" to join the feet to the center. Stephen suggested using a mortise & tenon joint instead.
Either way works fine by me - in some ways the M&T joint would be easier as I wouldn't have to worry about cutting a dovetail on the center portion or on the ends of the "feet". The mortises and the tenons would be easier to cut. The joints should be similar in strength.
So - what does the collective wisdom say?
