Death wish anyone?
Death wish anyone?
Death wish anyone?
Denis Ch�nard, Orl�ans, Ont.
>A local high school in my area is restarting their woodworking program (which is wonderful in itself). The man running the shop asked me for advice on a number of things. He also told me that they were throwing stuff away, and that I could come over to see if there's anything I'd be interested in.
They had switched over to a central dust collection unit, and had a bunch of leftover 1 HP DCs (Mastercraft mostly, Canadian Tire house brand, good machine for the money). I selected one from the bunch, then noticed that there was the body of another one (minus the stand and bags) on the floor. I went and felt the impeller inside and found out that something was wrong, as if the impeller had been "fixed". So I took off with that one too, thinking that at worst I'd get a free motor from that.
Yesterday I disassembled that unit and found this:
http://www.famillechenard.com/deathwish/impeller.JPG
Someone at some point decided to "fix" the broken impeller with pieces of 1/4" plywood and carriage bolts... Keep in mind that it's a plastic impeller, that one of the blades had been totally busted, and that the impeller frame is cracked up to half its diameter... Now consider that this impeller spins at 3450 RPM...
Obviously not all people value life the same way...
DC
After seeing this I took the other unit apart just to make sure, and that one is in good shape... BTW, the Mastercraft DC does not have a "grate" thingie at the inlet. The upside is that shavings don't get trapped and clog the unit. The downside is that anything that gets sucked in the hose will hit the impeller. Something to keep in mind...
Re: Death wish anyone?
You mean like your hand?
Dan Mitchell
>"BTW, the Mastercraft DC does not have a "grate" thingie at the inlet. The upside is that shavings don't get trapped and clog the unit. The downside is that anything that gets sucked in the hose will hit the impeller. Something to keep in mind..."
I recently got my 1st DC unit, a Penn State 2hp DC2000B. After assembling the machine, I naturally switched it on as it stood to make sure all was well, & to "gauge" the effectiveness, moved my hand down near the inlet. I was startled at how powerful the suction was, as it very nearly drew my hand right into the un-screened opening. Wouldn't have been as brutal as that metal turning lathe thing, but potentially quite nasty none the less.
The impeller on the Penn State is Steel, so presumably more robust than plastic. Learned my lesson about putting my hand near the opening, but I have been wondering it I should fit some hardware cloth or the like in the opening.
Dan
Re: Or this?
Bob Entwisle in NJ
>First time i tried my new (used) DC out I tried it out like a shop vac, sweeping piles of sawdust from 2 feet away, until my DC remote control flew into the hose! I hit the off switch on the DC and as it wound down expected to hear at any moment, the remote being shreaded. When the impeller spun down, i took the intake off and was glad to see the screen. It saved the remote, but doesn't seem to affect the airflow at all, and so far I've not experienced any chips or shavings clogging it up. (screen in next post)
Re: Or this (2)?
Bob Entwisle in NJ
>here's the screen that saved the remote
Re: Or this?
Bri in Mtl
>I had to take the screen off due to pine chips clogging. I do pay the price sometimes though...
Photobucket
Silver lining
wilbur
>But think of how much better your dust collector will work now that the chips will be sliding more smoothly along the non-stick interior. :@)
A photo like that demands a story.
>Wow. So what happened there? DC sucked up a spray can? So what happened? The can was obviously empty at the end of the story, but how full was it at the beginning?
Happy Woodworking!
Hmmm... it didn't save my vehicle registration...
Scott in Montana
>Upon returning from licensing my truck, I set the registration and proof of insurance paperwork on top my workbench and got distracted. I had been sanding there the night before and had a flexible duct to my central dust collector a couple of feet away. Was going to use the miter saw and flipped on the dust collector without checking to see if other blastgates were closed... out of the corner of my eye I saw my paperwork disappear. I'm just not faster than my dust collector.
Scott
Re: A photo like that demands a story.
Bri in Mtl
>Not much to say really. My shop is a small and I have about 15 feet of hose that I connect to the various machines and use to vacuum up the floor. Left the hose hanging loose next to the can, reached up for 1 of the 2 remotes I have hanging from the ceiling and bang, it was gone!
Photobucket
Tony - Memphis
>Me too, and that's what happened to my X10 remote for the DC recently. Good thing they are $1.99 on Ebay in packs of three.
Tony
Yabbut... the rest of the story.....
>I want to hear what exactly happened when the can hit the fan ;)
Was there a bang? Did the blades just slice the can and the pressure just fizzed out?
IF there wasn't a huge explosion (doesn't look like it from the photos) then there should have at least be a huge mess of black paint everywhere, or something. What was in the can? It doesn't look like it made much of a mess inside the fins or anything.
Happy Woodworking!
Re: Yabbut... the rest of the story.....
Bri in Mtl
>I thought it was obvious from the photo,(and Wilbur noticed it) but it was a can of Topcote.
Was just a big bang, the can does say it's flammable so after I wondered if it could've caught fire. Didn't though.
Ahhhh......
>TopCoat? Ah..... I saw Wilbur's comment "... non-stick interior..." and all I thought of was PAM non-stick frying pan spray.
Happy Woodworking!
Hank Knight
>I handled an OSHA case several years ago that involved a can of silicone lubricant that got sucked into my client's dust collection apparatus. It hit the impeller which punctured the can and ignited a large explosion. The operator was seriously burned - 2nd and 3rd degree burns over his face, neck and chest (He was standing next to a high bench that protected the lower part of his body. The dust was polyethylene dust which OSHA rates as a class 4 explosive. The dust and the lubricant both ignited with explosive force which is why the explosion and the injuries were so serioius. If I recall correctly, fine wood dust is also rated a class 4 explosive.
