OT-Engine won't start all of the time
Joe Pack
>A good friend just took his 2001 motor home (Chevy 454 engine) out of storage. The battery was dead, but started with a jump start. With the original battery being 6-7 years old, I convinced him to buy a new one, which he did.
With the new battery installed, the engine fired up instantly...until the next day. He tried to start the engine, but got only 3 clicks, then nothing. Thinking the new battery was dead (very unlikely), he jump started the engine and it fired right up. He let it run only a few seconds, not nearly long enough to charge it up, then shut it off and fired it up again. The engine started immediately. He repeated he off/on cycle an estimated 12-15 times with no problem. Even a few hours later, the engine started immediately.
The next day, the entire story repeated itself...only a click (a single one, he says), then a quick jump, then no problem starting/stopping repeatedly. He called me again and I told him it sounded like a ground/bad contact problem. I went over to help (complete with wire brush, terminal cleaner and corrosion spray. We took off the battery terminals, cleaned them shiny (the positive had quite a bit of corrosion, the negative was fairly clean), applied sprays and reinstalled the terminals. The engine fired up immediately.
I did suggest that he also take apart and clean the ground at the engine block. He crawled under the motor home and found the block ground, but was a bit uncomfortable laying in 2" of snow, and with fingers pretty much numb from the 20 degree temps, working barehanded and having wet sprays all over his hands. He said he would do it tomorrow (today).
He called about 20 minutes ago with exactly the same problem...a click, a quick jump then repeated ability to start the engine. He was on his way out to clean the block ground after we hung up.
Based on my own experience driving junkers for so many years, I think I'm on the right track thinking it is a ground or connection problem. My friend, on the other hand, is ready to start replacing selenoids, starters, etc. I really doubt the problem is starter related; I don't see how jumping from a little Pontiac Sunbird would negate a bad starter. I hate to see him spend money if he doesn't have to. Am I on the right track here? Is there something else I should be considering? This problem is new; no problems like this before storage.
Any ideas would be appreciated.
Thanks.
Joe
