2 Router Table questions
Tom Pilsbury (Chicago)
>1. Is it absolutely necessary to laminate the table top? I just completed the top using 2 sheets of MDO with a hardwood border. It is flat and smooth. I'm a little bit hesitant to laminate it because I've never laminated anything before and I don't want to ruin it. And, more importantly, my shop is in the basement with little ventilation and I'm working about 8' away from the water heater and furnace. The warning labels on the container of adhesive caution you to have ventilation and keep away from open flames so that scares me. I don't want to wait till spring when I can work outside. So, can I skip the laminate?
2. I have and abundance of 2'x4'x5/8" OSB that I picked up for a buck apiece. Is that stuff okay for the table base? I used some of it for shelves in the basement and it seems pretty sturdy. I figure I can always paint it. And as Oliver Hardy would say, "No one will be any the wiser".
Guess you can tell this is my first router table, huh? I'll probably be back with more questions. Please bear with me. I'm learnin', man, I'm learnin'.
Re: 2 Router Table questions
Ron Hildreth
>Tom,
By no means does your router table have to be laminated, but a slick surface does help. Especially if a constant feed rate into the bit is required for a better cut, as in routing cherry, that has a tendency to burn if the feed rate is too slow, or inconsistent. This can be achieved with a couple coats of poly, followed by a good thick coat of wax.
Another option is a trip to your local cabinet or counter top shop and ask them if they have any sink cut outs, and make your router table from one. These are really useful for making tables for any shop machine - in feed and out feed tables, band saw and drill press tables, even a small wall mounted writing desk near the phone for when that next customer calls and you need to write a note to yourself what he said!
Still yet another option would be to lay a piece of 1/4" melamine on top and just tack it down at the corners.
Ron in Iowa
Robert R Clough - Thorncraft
>Tom
I see nothing wrong with using MDF as a table top - provided it is supported well from below. Remember MDF has little strength that way. A router hung in the middle will strain and probably deform the top.
As far as lamination goes, there is no need. I have used MDF as a router table top and was the H E double crooked letter out of it and kept it waxed. It worked fine. Now I have a JoinTech system which comes laminated.
OSB can be used for the base,and 5/8" is the thinnest I'd go - and brace it at the corners.
Ron has some useful advice above.
>I have a number of tops made from sink cutouts. I have a friend in the cabinet business and when I check in with him he gives me the cutouts. I often find they are concave on the side with the laminate. What I do is give them a liberal coat of PVA glue and clamp them together bulge to bulge and the flatten each other out. Now you have a top that is about an 1 1/2" thick with laminate on each side. Stable and sturdy.
My friend made a dedicated mortiser with a laminated top. It has held up perfectly for about twenty five years in a commercial shop. He was concerned and made a spare top while he was making it, but has not needed it.
Hal
>I put laminate on my router table (several years ago) and would do it again. Water based contact cement available at Ace, etc. takes care of the odor and other concerns. Good luck. Hal
Ron Hildreth
>Barry,
Thanks for reminding me that you never get one cut-out, but two for the reason you mentioned. I've noticed over the few years I've been a member here that you and I think alike on a lot of subjects!
My counter top shop used to charge me a buck for each cut-out I got from him (still cheap!), but after I started bringing in a few customers to him, he's not charging me any longer. I can think of a thousand shop uses for them in the shop!
Ron in Iowa
Kevin Rabenaldt
>Laminating is not difficult. It is the best way to go. If you do not laminate, then seal the top and bottom by some method of finish.
Kevin
Thank you all
>Excellent advice from some experienced woodworkers. I don't want to get all mushy here but I really admire you guys (and gals). Your skills are super impressive and you're always willing to share your knowledge. Thanks again.
>Good Afternoon Tom,
I believe you can get by nicely with your table top made from MDF. I have used MDF as an auxiliary table on my DW planer to thickness veneer, and it has held up fairly well. I keep it waxed. I have noticed, however, that the surface is wearing and will have to be replaced. I encourage you to laminate your MDF. Such action will make it a very permanent component. Either way, it will work well for you.
George
>My shop is very colorful. Some of these things date back to the days we thought burnt orange was the rage. Lately I have tried to be a little more selective and not just utilitarian. My shop cabinets will never look as good as Clay Foster's. Never the less, I have found a dozen or more uses for them.
Didn't you do the Chantix? Still working for you? It's been a great thing for my son.
Yup- No cigs for 10 Mos. now!!
Ron Hildreth
