Custom Closet *LINK*
Carlos Clarke
>I going to build a large custom closet for my wife. I want to build it on a track based system where the dividers, shelves, and drawers hang from a track that is screwed into the studs. I've found one source for the track at $12.99 for a four foot section. Does anyone know of another source? I'd also be interested in looking at plans for the components even though it seems pretty easy to design them myself.
Thanks.
http://store.easytrack.com/products/product.asp?searchby=pid&pid=927
Re: Custom Closet *LINK*
Make some French cleat
Grant Smith
>Just Google "French Cleat" and you'll see the design of an easy to make wall track system that you could use. You could put two tracks on the wall, one high and one low for extra stability and holding strength.
Regards,
Grant in Iowa
Re: Make some French cleat
Carlos Clarke
>I was considering French cleats. The metal track seemed to be easier but the cleats would have a cleaner look. I'm not sure how much weight I could hang off the cleats. The track claims that an 8 foot section will hold 1200 pounds.
>In both cases the strength of the system would be determined by the strength of the connections of the pieces to the wall and to the components. At least until you reach the limit of the tracks or cleats and they begin to deform or fail. A 16d nail will hold about 100 lbs in shear. Its the diameter of the shaft that tends to determine its strength in shear, along with the sheet rock, the wood of the studs and whatever the system of components are built of. So if you use screws with shafts the same size as 16d screws, each one will carry at least 100 pounds. This is conservative. I have seen claims that fasteners hanging in drywall alone will support over a hundred pounds.
