Tips/Tricks Setting Up & Using a Cabinet Scraper
Mike Baratta
>Everyone,
I just purchased a Stanley No 80 Cabinet Scraper. Its primary use will be to flatten and smooth glue ups for table tops and such. What advice can you give me on how to set up and use one?
Thanks,
Mike
West Chester, PA
Re: Tips/Tricks Setting Up & Using a Cabinet Scraper
>Of course, it should be sharp with a pronounced hook. Expose the blade the thickness of a business card and tension it to a mild arc. Shavings should be almost transparent.
Clint
Mike Baratta
>Clint,
Do I want the bevel of the blade away from me or toward me as I push the tool?
Mike
Bill Kay
>I have been using the hand held card or cabinet scrapers for some time now. You can achieve a very smooth finish in short order.
A few links to get you started with the Card or Cabinet Scrapers.
http://www.taunton.com/finewoodworking/pages/w00007.asp
http://www.cabinetmaking.co.uk/scraper1of2.htm
http://www.timbecon.com.au/assets/files/0401_web.pdf
http://members.aol.com/illinewek/faqs/scraper.htm
http://www.woodzone.com/articles/scrapers/
http://www.inthewoodshop.org/methods/wwc07.shtml
http://www.joewoodworker.com/scraper.htm
http://www.fine-tools.com/G10004.htm
look hereabinet Scrap *LINK*
Dan Donaldson
>This is a search of Woodcentral. There are several articles on scrapers and some other info.
scraper articles
Ron Hildreth
>Mike,
Either way. Which ever way feels good to you, as either way is the right way! It's one of the few pieces of shop equipment you can say that about!
Ron in Iowa
Hal
>I use the method Chris Schwarz presented in Pop Wood, Feb.,'07 issue. Never had any luck before, but am pleased with the results using his method. If you can't find that issue and would like to have a copy, let me know. I'll make a copy and send it to you. Hal
