WD40 and diamond stones
Doug Reynolds in Seattle
>I saw Larry Willaims new video on making hollows and rounds. In it he uses WD40 to lube his Arkansas stones. I wondered if I could use WD40 to lube my DMT diamond stones instead of water?
Re: WD40 and diamond stones
>We discussed this briefly at our club meeting this week. One experience was oil made the diamond grits loosen and fall off. The info that came with one of my diamond stones said "use water only to lubricate, do not use oil".
Rick Christopherson
>I do not know the answer to your question as it pertains to stones, however, it should be pointed out that WD40 is not a lubricant. If you look through the manufacturer's literature, you will not find the word "lubricate" anywhere.
lubricant and cutting fluids
Bill Tindall, E.TN
>I don' t know the properties optimum for cutting fluids but they don't seem to be lubricants. I suspect lubricating something and what ever properties it takes to float away abraded grunge are quite different. In fact it seems that "lubricating" the abrasive surface is NOT what one wants to do.
I "lubricate" my diamond stones with very dilute water based cutting fluid. It seems to act as a surfactant and it works great. I unknowingly "acquired" 11 gallons of the stuff when I bought a used plastic 250 gallon "cube container". The metal slides more smoothly with this stuff on the stone and the grunge seems to float away efficiently. And the diamond grit cuts aggressively. Before, I used WD 40.
I only use WD40 on my cast iron plates charged with diamond powders. It works the best of anything I have tried. Metal slides smoothly and grunge floats away.
I used Kerosene on oil stones before I found ways to sharpen that are vastly faster.
WD-40 as lubricant *LINK*
>>...WD40 is not a lubricant. If you look through the manufacturer's
I'm curious, what keeps this persistent rumor going? I've read it over and over on the web. WD-40 is in fact promoted as a water-displacing penetrating lubricant. Here are some places where the manufacturer uses the word "lubricate" or "lubricant":
--- From the WD-40 MSDS (link below), product use is listed as: "Cleaner, Lubricant, Penetrant", content includes: "Petroleum Base Oil".
--- From the WD-40 web site, http://wd40.com/Brands/wd40.cfm, the statements:
"WD-40...lubricates just about anything", and "THE FIVE BASIC FUNCTIONS:
"CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape, stickers, and excess bonding material.
"DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
"PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
"LUBRICATES: WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts.
"PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements."
--- From the 50 year anniversary can on my shelf: "LUBRICATES Moving parts such as * Hinges * Wheels * Rollers * Chains * Gears"
--- From company communication: If you write to them and ask, they will (at least they have in the past) responded that WD-40 is a "light lubricant".
WD-40 MSDS
Kerosene
Joe Burke
>FWIW .... I use kerosene on my diamond stones. I grew tired of the rust that seemed to develop when I used H2O on my diamond stones ... I'm sure besause I wasn't fanatical with clean up. I used kerosene on my Arkansas stones, so I switched to that.
No problems that I can see.
According to DMT, Yes
Jack
I know it says to use the sharpener dry or with water, but can I use oil anyway? Can I store my DMT stone in kerosene?
While we recommend you use DMT� products dry or with water only, it is acceptable to use a variety of lubricants when sharpening with DMT� products. Mineral oil, mineral spirits, kerosene, WD40 can all be used without harming your DMT� sharpener. We do not recommend storing your DMT sharpener in kerosene. DMT� recommends that you always wipe your Diamond and Unbreakable Ceramic Sharpeners clean and store dry after use.
http://www.dmtsharp.com/dmtdiff/faqsfeedback.htm#Dry
7-UP ???
>Maybe it's 7-UP that is trying to make sure people don't mistake their drink for a lubricant. Or pehaps Heinz-57 wants to make sure you know their's is a sauce and not a lubricant. No, wait... it's V8. They want you to know it's a vegetable, and not a lubricant.
Products with letters and numbers for names are so much fun!
Happy Woodworking!
