TS: Square at 0 deg but not at 45 deg?
Dominic Greco in Richboro PA
>OK, I'm going a little crazy here!
I just spent my afternoon trying to tweak a cross cut sled for my Unisaw only to find that it's giving me DEAD on square cuts at 0 deg (90 deg to the table) and NOT square cuts when I set the blade to cut 45 deg!
I had made this nifty cross cut sled last week and got it so I could make dead on square cuts. I cut some nice wide test pieces and was able to verify that I was getting perfectly square cuts. HOWEVER today when I went to change the blade angle, all hell broke loose. I thought that I had a made an error and that I needed to re-set the fence. At this point I thought that the piece of plywood I was using as a fence was flexing under load. So I scrapped it and made a nice sturdy L-Shaped fence out of (2)pieces of plywood and started over.
But as soon as I tilt the blade it goes out again! I used my 12" Starrett square to check the pieces and I'm out about 1/32" over 9".
Has anyone else ever had this problem? I used to expect this kind of thing from my old Craftsman Contractor Saw. But not my Unisaw!
And is 1/32" over 9 or 10" something to get upset over?
See ya around,
Dominic
