OT - dead laptop
OT - dead laptop
OT - dead laptop
Carol - now in NC Nebraska
>OK, computer guru's. How I appreciate all the talent on this board!
My IBM Thinkpad is dead. Won't boot. Was running, went to sleep and failed to wakeup. Was plugged into AC at the time. Can it be revived? How?
To put things into perspective, it was a used machine 3+ years ago. I am not adverse to getting another laptop. I would again look at the used market. I am not married to IBM. This is my second. Rugged machine, but is there something "better" out there?
Re: OT - dead laptop
Joanne Adler in Pt. Pleasant, PA
>You might try popping out the battery and see if it will start with just AC plugged in. Or take out the battery and put it back in, making sure it clicks firmly into place. Sometimes a laptop won't start even with AC, if the battery isn't making a good connection.
>Tried that - no joy. But thanks.
What do you mean by dead laptop
Dustmaker Mike
>does it start to boot then stop or will not even power on? If it starts to boot then does not find the hard drive there is a drive fitness test you can run on it to maybe repair it. If does not even power on look at the block that comes from the power plug is there a light on it? If so is it on or off? If off then the wall wart is bad if it is on then I am out of guesses. Good Luck
RIP - Power Supply
Re: What do you mean by dead laptop
>The wall wart has no light. The light that used to flash before boot-up is not doing its thing. I think Clint is right. Dead power supply. Can these things be fixed? Hassle? Expensive?
Recommendations on a replacement laptop still welcomed.
Fortunately there is nothing on it that losing will give me grief. I needed to upgrade my GPS program anyway. I use it for that mostly, but it is useful for PowerPoint presentations...
Glenn Madsen, near San Francisco
>My new in 1999 Thinkpad finally bit the dust this winter.
At $699 for a new one from CDW, I wouldn't THINK of repairing the old one any more. So I bought a new Lenovo Thinkpad this last week. The old one owes me nothing any more. And most of the old goodies will work with the new one, like mouse, keyboard, etc.
That's what I did. I may not get another 8 years out of this one, but it was a good deal. What I really wanted was the $2500 Mac laptop, but not this month, and likely, not next month either.
Re: OT - dead laptop- new laptop
>Which model Thinkpad and what is Lenova? I got my last two laptops from usacomputer.
And you got a new one for $700? WOW! Details please.
Re: Lenovo ...OT - dead laptop- new laptop *LINK*
Bob Entwisle in NJ
>IBM sold its PC division to Lenovo
http://www.ibm.com/ibm/us/en/pcannouncement/
>Thanks, Bob.
I looked at the link. Something to think about, but I'd still like to try to resuscitate this one if possible.
Failing that, what does one do with a dead laptop?
Re: OT - Power supply? dead laptop- new laptop
Bob Entwisle in NJ
>If you can determine if wall wart is the problem, a new one is less than $20. Just google "IBM Thinkpad Power Supply"
cfreeze
>Like others have said, you should try replacing the power supply before you do anything else. If you have a multimeter, you could test your existing supply by checking for voltage. The voltage rating of the power supply is on the bottom...check to verify that's what it is putting out.
It's also within the realm of possibilities that the DC input board in the laptop is fried...I've seen a few suffer this problem (I'm a systems admin by trade, and deal with laptops on a daily basis).
As for a replacement, we used to buy Thinkpads when IBM made them, but now that Lenovo owns the brand, we've switched to Toshibas. Evidence would seem to suggest that Lenovo's customer service is not nearly as good as what IBM used to provide.
The hard drive on many Thinkpads is also easily removed..usually a screw on the underside, and the drive slides out of the case. If you need data off of the disk, pull the old drive out and connect it to your new laptop using a universal USB hard drive adapter. Such a beast can be purchased here:
http://eshop.macsales.com/item/Newer%20Technology/U2NV2SPATA/
If you do get a new laptop, the old one can be recycled. Many manufacturers have a recycling program for dealing with their old equipment, and some stores will accept old equipment for recycling..sometimes at no charge to you. I've also seen some organizations that collect old electronics as a fundraiser. Pull out the hard drive first before you give it away though...you don't want somebody getting any of your data off of it!
Howard Norman
>It sounds like the wall wart has gone bad, assuming that you have it plugged into a good power outlet. Don't laugh, I once thought I had a bad wall wart for a Thinkpad and I just had it plugged into a wall outlet that was not working. You can Google Thinkpad power supplies and come up with online sources. It would be nice to find someone locally that had a similar Thinkpad and try their ac power supply.
Howard
>Thank you. That is the most helpful response to date.
I will check the wall wart power supply and report back.
Re: OT - dead laptop UPDATE
>Wall wart tested dead with VOM. Another on order. Thanks.
Howard Norman
>Sounds like you have isolated the problem Carol.
