OT ? - Roof singles
OT ? - Roof singles
OT ? - Roof singles
Tim Caley - North Little Rock
>I had one shingle blow off of my house in a storm the other night. It is right in the middle of the roof, about halfway down from the peak. Do I need to worry about repairing it? Our roof pitch is very steep and I am not comfortable going up there, so I would have to hire it done.
Thanks for any help.
Re: OT ? - Roof singles
>As a Home Inspector I know something about this.
I assume you are talking about Asphalt shingles and they are the three tab variety.
If so, if the one that blew off exposed the joint between the shingles below you need to replace it. If is did not expose the crack or ends of the shingles, you can probably let it go. So there is a two out of three chance you can ignore it. You might be able to ignore it even if it is one of the the ones covering the crack below, but it would be riskier.
If they are not three tab ashalt shingles, describe what you ahve and we can take another whack at it.
Tim Caley - North Litttle Rock
>You are right, it is a three tab shingle and unfortunately it is on the front side of the house.
Dave Peebles Lyons, Ohio!
>Hi Tim,
I would replace any shingle that come off my roof. It may be time to have someone check it out anyway. If one came off, many more may follow.
Best wishes,
Dave
>I tend to agree with Dave, I would replace the shingle if I could. The roof is the most important element in protecting your house from the weather. You start to take damage the moment it starts to leak.
You have not mentioned how old it is or whether you have spare shingles. (When I was building, I always left spares at the house. It amazed me how many people threw them away.) If you do not have spares, a skillful roofer may be able to remove a matching one from the rear roof and put it on the front and put the mismatched one on the rear. Maybe he can pick a place that won't show too badly to steal the replacement.
The other consideration is the age of the roof. IF the roof is in the first 3/4 of it's life expectancy it may be worth repairing even if it is not leaking. But they get brittle and more difficult to repair with age, so if it is approaching the end of it's life and not leaking you might want to ride it out and replace the entire roof when the time comes. Working on a very old fragile roof might do more harm than good.
Justin Szeliga
>There are a number of questions that are pertinent in a case such as this. How old is the roof? How much of the shingle blew off?
If you look at the roof is it looking nice & flat & even, or are the shingles kinda crumbly, cracking & wavy? Which way does the weather come from most of the time.
The amount of shingle that broke off is important, as you may have a hole exposing tarpaper if enough broke off. That makes a leak much easier to form. The real question now is are you willing to save the repair price of the shingle now, & if a leak develops, pay later for a shingle repair & pay for or do some plaster/drywall repair?
All that said, I always go look at the roof problems, never try to diagnose by phone or email. You just have to see the roof to give a good opinion.
Peace
Justin
>Thanks to all for the responses. You have confirmed my thoughts, but I just wanted to make sure before I called someone out to have a look at them as I am certainly no expert.
