Re: Bubbles in poly
Dave Bair, Eaton Rapids, MI
>If you are getting different levels of gloss, probably the wood surface is not uniform. Usually, some of the grain is not filled by finish and some is. Between coats of poly, try a light sanding with 320 or 400 grit paper. That will create a substrate with a more uniform level of gloss for the next coat. Do not use mineral spirits to clean up the poly sanding dust; it sometimes seems to react with the remaining poly and creates an real mess.
If you get bubbles (or even dust nubs), try tipping them off with a dry brush or a folded square of cheesecloth. You will end up with a thinner coat of poly, but it will dry faster. Bubbles generally result from your brushing technique (I cannot apply a finish coat of poly using any type of brush, so I have no hints. I just see so many articles about brushing it on that I assume my technique is at fault) or from air being released from the open grain of the wood for the initial coat.
