>Divide 360 (total number of degrees in a circle) by the number of sections you want (in this case 3). This will give you the number of degrees between the lines (in this case 120 degrees. There are a number of ways to lay this out, but I would probably draw the center line of the circle and measure of the other two lines using a protractor.
>that thing we learned in grammer school? Use a compass to draw the circle and then using the radius measurement (don't change the compass setting) start around the circumference and mark each radius. This gives you six equal arcs. Just use every other one.
>If you draw the circle with a compass or any such device, keep it set to the radius or if it's too late for that, set it to the radius.
Take the compass and set the point on the perimeter of the circle and make a tick mark where the pencil touches. Step the point to the tick mark and do it again, and again until you go all the way around. You will find that this divides the perimeter into six equal segments. Use every other one to have thirds.
Walking it off with the compass is what I was looking for. I went ahead and cut out the center before I thought about laying out the legs, otherwise Rob's suggestion would have been the approach I'd have taken.
Once again, WoodCentral proves itself to be well worth the price of admission. 8^]
>Finally got back to the shelf this afternoon. It took me only a few minutes to step off the leg location with the compass, mark my spots and drill the mounting holes.
This is a great group of folks and a tremendous resource.
