REAL MILK PAINT
cherry wood -- finish??
Dan Collins
>I am building a cherry hardwood computer table. I am not putting any stain on it. I like the look of a natural wipe on poly varnish. I am concerned that as the cherry ages, the table will have lighter spots left on the top underneath where the computer sits, because the area under the computer won't be exposed to the natural light. I am thinking maybe I should let the table age in a sunlit room for a couple of weeks before I put the computer on it. Has anyone had this type of problem, and if so, is there a solution? Thanks. Dan
Re: cherry wood -- finish??
Wood is going to do what wood is going to do
Dustmaker Mike
>I would put it in the sun for a few days let it darken then not worry about it. It will darken more around the computer stuff but when you remove it the rest will darken up also. In other words let it do what it will do.
Re: Wood is going to do what wood is going to do
Steve Schoene
>The other thing you can do, in addition to the initial suntan, is to move the computer around on the desk periodically for the next six months or a year.
staining cherry
Bill Tindall, E.TN
>When cherry is stained properly, the color of aged cherry is promptly achieved and the light exposure issue becomes irrelevant.
I suspect that many who eschew staining do so because they have not had success. Good staining relies on meticulous sanding. After sanding I apply stain with a rag dampened with stain. While this application technique is not accomplished quickly it does precisely control the depth of color development. On cherry, when I am done staining the cherry looks like it is 10(arbitrary number) years old. On walnut the wood color looks new even after it is exposed to bleaching sun for 10 years.
Short of sealing furniture in an oxygen free dark case the woods fresh surface color will not last. Cherry will darken in hours in bright sun; walnut will lighten in a few weeks, green poplar will turn brown and white maple will turn brown. The only way to stabilize a color is by staining, preferably with mineral pigment stains. .
I agree!
Lee Schierer - McKean, PA
>You will get shadowing on pine, cherry and walnut (probably oithers too)if you leave an opaque object on the surface for a prolonged period of time. This shadowing never quite goes away because the wood that was exposed also tends to continue to change slightly over time. I feel it takes Cherry about a year to reach most of its final color. Moving things around on the surface is the best way to avoid shadowing.
Lee
