Cutting you own stringing? Ideas please
Henry (Raleigh NC)
>I have recently been dabbling with adding stringing to my projects and I�d like to hear how others do this. A recent Popular Woodworking article has some details on processes to use for creating the groove to lie stringing in, as well as some ideas for actually making the strips/stringing. I am looking for more help.
I am using a very small (1/16", maybe 3/32"?) router bit and a router table to create the shallow groove for the stringing. That has worked reasonably well.
I have more difficulty with cutting my own stringing. The PWW article suggested the possibility of using a marking gauge to cut narrow strips from veneer. That is a usable approach, certainly for small pieces. The setup is short and it is quick. Splits along the grain have been a factor using this approach.
I am resawing scrap lacewood pieces with my TS or BS to create narrow veneer-like pieces. Then I am attempting to cut the stringing from those veneer-like pieces. Typically for me these pieces are only an inch or so wide, so it seems inappropriate to label this as veneer � they are thin strips.
Dimensional control for the actual stringing is only critical in one dimension; the stringing needs to be the same width as the groove I have cut. The other dimension just needs to be larger than the depth of the groove, and any additional material will be sanded off. That one critical dimension is where I am having issues � I need more precision in at least one of my cuts so that I can achieve that constant thickness or width of the stringing. T
I am now trying to make picture frame stock that incorporates stringing. Here I am trying to do 6' pieces - not necessarily with long continuous pieces of stringing, but using many 6" pieces gets old. So here I am trying to use longer stringing pieces, at least 12-18". For this I have also tried a second approach suggested in the PWW article � using a zero clearance secondary table on the bandsaw and cutting the stringing from the veneer strips. That has proven faster, and reasonably accurate, but not accurate enough I think. Cutting the stringing on the TS has not worked well; the resulting stringing does not have enough rigidity to avoid flutter near the back of the blade and the rising teeth take some or all of the piece. It just does not survive the TS journey with a consistent dimension.
One change that I expect would make a difference would be a much finer tooth BS blade. As I am thinking about it, I would guess that sandwiching these thin strips between thin plywood might also be a way to keep it stable; that seems like a tip I have seen for cutting thin metal sheets.
Anyone else cut their own stringing? How do you accomplish this?
Thanks for your ideas.
Henry
