Re: Strength of steel angle for mobile base *LINK*
ScottS
>Unfortunately, there's no simple chart for this situation. If you really want to know the answer to this question, you'll need a copy of Machinery's Handbook or perhaps some other physics or engineering text. There's a great little program called BeamBoy that will do all of the necessary calculations for you. It's a bit rough around the edges, but basically you can define a beam, supports (= casters), and loads (= jointer) and it will compute the deflection. IIRC, it has built-in tables containing the modulus of elasticity and moment of inertia for various steel forms (angles, I-beams, U-beams, etc) though you may have to poke around the program to find them.
As far as assembling the steel to create a mobile base, I think you're going to have to weld. Of course, I own two welders and think that welding is more fun than woodworking... Welding would give you the cleanest design, in my opinion. If you don't weld, then you'll have to add additional metal to reinforce the corner joint. When you butt two L-shaped pieces of metal together at 90-degrees, only two of the faces will overlap. You'll need to add a 90-degree bracket to tie the other two faces together. And I would think you'd need some fairly substantial bolts.
Someone suggested buying a cheap wire welder. I would caution you against this. The problem is that the welding capacity of a cheap, 120V wire-feed welder is limited. A 220V wire-feed welder (a.k.a. MIG, a.k.a. GMAW) is really a much more versatile tool. Think of the 120V welder as a benchtop table saw and the 220V as a contractor or hybrid saw. Miller and Lincoln are the only two brands to consider and they'll set you back around $600-700 for a new 220V machine. Also, keep in mind that MIG welding and woodworking don't mix. MIG welding creates lots of sparks, which don't mix well with sawdust, finishing materials, or raw materials!
Probably cheaper to have the work done by a local shop. You might also look into having a mobile welder come to your place. If you prepare the metal, it shouldn't take that long to get it all welded together. See if you can find someone who works in your area that will stop at your place on their way home or between one job and the next. Or use classified ads like Craig's List to find a hobbyist welder that can do the work for you.
BeamBoy
