Shellac Seal Coat problems
Alan Tolchinsky
>Hi All, I use Zinnser SealCoat after staining to seal the stain and reduce the number of wipe on poly coats afterwards. But when brushing as carefully as I can, I always get some runs and other undesirable surface defects. Even though I'm saving time with fewer coats of poly, the shellac coat seems to take too long to correct and smooth. Any suggestions as to what I'm doing wrong? I'm trying to apply as thin a coat as possible. Thanks in advance.
Re: Shellac Seal Coat problems
>Trade your brush for a pad. Few brushes will hold enough shellac to make a full wet stroke. When padding (not wiping) you bring your pad down to the surface and then left it off at the end of the stroke (imagine a touch-and-go plane landing). This feathers both the start and end of the finish applied and minimizes lap marks.
You can also add a few drops of pure turpentine to shellac to act as a retarder. This will slow the drying and allow the shellac to level out more to reduce any laps. Do NOT try to work the finish like you would with poly; you'll have a mess.
If, however, you're putting oil poly over stain, you really shouldn't need the shellac sealer.
Putting a waterborne over some oil stains or especially over dye can result in adhesion issues or leaching of the dye into the finish. In that case you do need the sealer to seal the oil and/or lock in the dye.
mm
Alan Tolchinsky
>Thanks Mark, The reason I seal with shellac is when I apply poly over the stain some stain always comes off in the pad. So I try to seal the stain in and save some coats of poly. Thanks for the tips.
Bill Sams
>Alan,
When I use the "sealcoat" I dilute with alchohol by 50%. It slows the drying process and use a 2" foam brush making sure there is always a wet edge, but still putting a light coats. For me the foam holds up except for those big jobs, then heck I use two or three foam brushes....:-)
