Re: Yes, it is that good
Dave Mount
>I replaced a 1990 vintage Unisaw with a SawStop a year or so ago. I made this change solely for safety, as I was in no way unhappy with my Unisaw. However, having gotten the SawStop, I have to say it is a nicer saw that the Unisaw was. Not by a ton, but noticeably. It runs smoother, it adjusts smoother, and the finish is better. The dust collection is better too. The Bies-type fence is well built and precise.
The riving knife was a huge step up. I had a microsplitter on the Unisaw, but I was always changing out throat plates when I needed to make a shallow, non-through cut. The riving knife hides behind the blade so it only very rarely needs to be removed, and even when it does, it's only a flip of a lever to remove it.
Only a couple things I'm not crazy about. One is that the throat plate is held in with an Allen screw which makes it take a little longer to remove it. Perhaps you could just leave that out if you wanted to. The other thing is that you can't run a dado without also changing out the cartridge (i.e., you can't just override the brake system to run a dado, you have to change the cartridge too). It's a small thing, but it just adds to the inertia of changing over to a dado.
I think it's a great saw and I can imagine you'd be disappointed with it.
Best,
Dave
