ADVERTISE HERE - FREE TRIAL
Silicone for installing glass in doors
Dave Bair, Eaton Rapids, MI
>I plan to install glass in some cupboard doors. In the past, threads here discussed setting the glass using silicone chaulk dabs in the corners. I plan to bed the entire permiter in chaulk, and attach trim to the interior part of the doors in the same way, all without any other type of fasteners.
Is there a problem with my approach? And which type of silicone should I use, the caulk type or the adhesive type?
Re: Silicone for installing glass in doors
Jason Roehl in Lafayette, IN
>Just go down to your local Borg and pick up 100% silicone caulk (plug for my dad's career employer, make sure it says "Dow Corning" on there somewhere). I believe DAP makes a Dow Corning silicone caulk. Not to mention, you'd be helping out, in a small way, the state of Michigan, whose economy is ummm...in the commode right now (Dow Corning is HQed there).
Jason
>The silicone adhesive type will work great -- the glass would have to be broken to get it out! An alternative is Polyurethane construction adhesive, although any of the adhesives or caulks would likely be adequate.
Clint
Removal will be hard
Lee Schierer - McKean, PA
>Silicone should work okay, but if you ever need to replace the glass or take the trim out you will have to cut the silicone to get it out. A little bit is all you need to secure the glass.
Lee
>Good Afternoon Dave,
I took my doors to a local glazer and had him do it. He used clear silicone caulk in a small continuous bead around the perimeter of the glass. The two doors of my corner dining room cabinet, my wife's Grandmother Clock, and my DIL's Regulator style wall clock were each done that way, and it works fine. I did not have to use trim molding at all. The jobs were neat, and the inside door presents itself very well.
There is an advantage to using silicone caulk because it retains its grip on shattered shards should rambunctious kids turn the home interior into an athletic arena. So far that hasn't happened here with my grandkids, but did in their parents generation.
George
Thanks for the info
>I installed the glass this AM using some Dow silicone adhesive for automotive trim. I did some experimenting yesterday to determine the right bead size. I'm planning to add the inside trim tomorrow; my job was not quite neat enough to hang out there alone.
Justin Szeliga
>http://www.crlaurence.com/ Has everything you could want or need for glass install. I know Alderfer Glass, a local glass company, & very good, carries & sells their products.
I believe that the acetic acid used to cure the easily available silicone caulks can be a bit damaging if it gets through the finish to the wood. I always use Phenoseal, which now has a good clear version. Removing the glass if it becomes necessary is best done with a razor scraper cutting the caulk from the glass.
Peace
JJS
